Question about Drills
While drilling into PVC pipe, the spindle suddenly developed a severe wobble: i'm getting a good 1/16 inch of play at the base of a 1/2 inch bit. What to do?
  • 8 more comments
  • williams523 Sep 06, 2009
    The drill press is a Shop Fox Model 1670. When i cleared away some shavings, I noticed a small washer on the floor. Is the thing shedding parts?
    Thanks
    Matt Williams
    williams@cheshire.net
    I have a three year old Shop Fox Model W1670. I was drilling 1/2 inch holes in PVC pipe and the press developed a severe wobble in the spindle (about a 1/16 of play measured at the bottom of the drill bit). Also, when i cleared away some of the chips, there was a washer on the floor which wasn't there when i started drilling. The washer was about 1/4 inch across.
    i looked under the chuck (that is, i looked at the chuck from below) and although i saw a small hole where a bolt or screw might go, i saw no bolt or screw.
    the chuck, however, seems to be very tight on the spindle itself.
    when i shake the chuck, it moves right with the spindle. it appears that the play is between the spindle and the tube (don't know the correct nomenclature) in which it slides.
    the suspicious washer turned ot to be from a piece that holds the depth indicator, so i'm pertty sure that this is non- contributory (found the bolt on the floor dome ways off and reassembled the whole deal)
    if there is a bolt that's supposed to go into the base of the spindle and hold the chuck, i guess i'll need another one.
    what size?
    thanks
    Matt Williams
    nope. got the shaft loosened up and the whole thing tilted so i could see what was happening in the inner workings of the chuck. there are no threads in there, so i presume that the chuck is press fit on (#2 Morse taper?).
    i see only one plastic washer, and it seems to cushion the top of the spindle where it meets the frame when the spindle/chuck is returned to the rest position as the spring brings the deal back up when you're done drilling.
    what do you recommend?
    thanks
    Matt Williams
    i have a three year old Shop Fox model 1670. there is a good bit of wobble (runout?0 which appeared when i was drilling into PVC pipe. i have looked inside the chuck, and i don't see a screw whcih would hold it onto the spindle. additionally, the chuck doesn't seem to be comming loose from the spindle, so i'm thinking that the spindle/chuck assembly is somehow loose in the tube.
    what's the next step?
    thanks
    Matt Williams
    oops, sorry... this is a Shop Fox Model 1670.
  • williams523 Sep 07, 2009
    alreadty tried another bit, but the problem continued. (that was about the point that i realized that i needed help) i've managed to swivel the head to a position where i can see up inside the chuck, and i can't see any place where there's a screw or bold which would hold it onto the shaft, so i would presume that it's press fit on a Morse #2 taper or some similar arrangement.
    the washer it shed was from a depth indicator part, so i don't think that's contributory.
    when the spindle is at the top of its travel, there's no play at the bit end, but as soon as you begin to depress the shaft (as though you were drilling inot something) the wobble becomes evident.
    i'm sure that the chuck is not loose on the spindle, and absent driving a wedge in there, i can't see how to get the chuck off the spindle. i don't think that this would help.
    thanks for your assistance- sorry if i'm a bit cranky; my daughter just totalled my car.
    what's next?
    thansk again
    Matt Williams
  • williams523 Sep 08, 2009
    I managed to get the pulley off of the top of the spindle, after figuring out (luckily before the threads were stripped) that this is a left hand thread.
    There are thread at the top (where the nut which holds the pulley on) and then there is a taper. I cannot tell if the tapered part is part of the shaft or is attached to it.
    When I look at the top of the spindle, i see a small hole (smooth- no threads in it) wich has been drilled into the center of the spindle and is about 1/8 deep. There are splines in the spindle, whcih appears to be in a shaft, and the splines of the shaft mate with those in the spindle, so that power is transferred from the drive pulley throough the spindle to the shaft which holds the chuck.
    I don't see any circlips any where. Is there an exploded diagram of this press available? The instruction manual, (although I can't find it at present) was stunningly unhelpful: basically it said "put it together, drill holes in stuff, have fun."
    Thanks for your help- i suspect we're on the right track.
    Can you tell me where to get an exploded diagram? (I think this would help with nomenclature)... the worrisome part is I don't see any circlips or bearing parts anywhere.
    Matt Williams
  • williams523 Sep 12, 2009
    hammer mode?? this is a floor drill, not a drill driver. Shop Fox Model 1670.
  • williams523 Sep 14, 2009
    i got the user's manual and downloaded it... there's a fairly good 'exploded diagram' in there, and from what i can gather, the chuck is well attached to the spindle, and there is freeplay between the spindle and the quill shaft, so i suspect that there are bearing problems.
    thus, two dumn questions:
    1) how do i get the spindle out of the quill shaft so i can look for the problem?
    2) where can i get new bearings assuming that that's what's wrong?
    thanks for your help... sorry if i'm a bit 'scattered,' but my eldest daughter smashed by car to bits last week and there's rather a lot on the plate.
    Matt Williams
    Top Expert:
  • 76,691 Answers
You mean the drill chuck shaft has the play? if so you have a bearing failure, take the whole thing apart and check the drive bearings for the shaft that the chuck attaches to.
Posted on Sep 14, 2009
  • 11,896 Answers
You may have to change the drill head. It may be bent.
Posted on Sep 12, 2009
    President:
  • 1,188 Answers
Try removing are readjusting the bit.
You might have accidentally put the drill into the 'hammer' mode. See if you can find a lever or sliding switch to change between drill and hammer modes.
Posted on Sep 08, 2009
    President:
  • 1,714 Answers
Make sure the bit is in the check straight and is completely tight. Remove it and inspect it and make sure it's round, maybe try a different bit to see if it spins straight.
Posted on Sep 07, 2009
  • 1,889 Answers
Have you tried another bit?
the bit may have become bent or, if the bit wobbles when you try to drill it may have lost the sharp edge on the bit tip
if the collet is wobbling : remove the (male) threaded shaft or,(female) internal threaded collet and, open the jaws fully you should see a left-hand threaded screw at the bottom of the jaws of the collet tighten it counter-clockwise
    President:
  • 1,564 Answers
Could you please clarify to me the Manufacturer and the model number of the press.
Posted on Sep 06, 2009
  • Dana Newcombe
    Dana Newcombe Sep 07, 2009
    It sounds as though the upper follow bearing has gone or become dislodged from its housing in the spindle housing.If you get on a chair and with a flashlight, look down into the spindle housing you should see a sealed bearing or a series of shims and a washer with a circlip holding it all together.If you raise the head, knock out the taper fit and remove the spindle stop screw. You should have a good idea how to disasasemble the top bearing. Let me know how you make out. Good luck, Dana
  • 426 Answers
Check inside the chuck to make sure the screw holding the chuck to the spline is tight, if not they use a nylon washer inbetween the chuckand the base to allow for wear check that also.
Please specifiy the make and model. Thanks.
Drill bit(masonry) wobble when test it.but it locks but just loose side ways.tnx
Try download once more. If there is any bit loss happened during download; this kind of error display might happen.
Jul 05, 2015 | Drills
Tip
Building your own ladder golf set
Building your own set for ladder golf is relatively easy and shouldn't take you too long. So you can be up and running in just a few hours.
You are going to need is 1" PVC pipe cut into 6 12-inch pieces and 9 24-inch pieces. You are also going to need 6 elbow fitting, 6 t-fittings. For the balls you are going to need 24 solid golf balls (2 sets of 12 in 2 different colors) and about 28 feet of nylon rope.
To building the ladder to form the base take 4 of the elbow fittings and two t-fitting and the 6 24-inch pipes. Connect the pipes to the elbows and the T's so that they flat side of the T is facing down. There should be an empty socket facing up. When you are finished you should have a rectangle that is 4ft by 2ft with 2 upward facing sockets to hold the ladder.
Next you want to build the ladder. Start by taking one of the remaining 24-inch pipes and attaching an elbow fitting to each end. Then attach a 12-inch pipe to the other side of the elbow. At the other end of the 12 inch pipe you are going to attach a t-fitting, continuing along the plane of the 12-inch pipes attach 2 more 12-inch pipes and in the cross plane attach a 24-inch pipe. Repeat this for the bottom step of the ladder. After you have attached the last pipe fit the open ends into the base and there you have your three step ladder for playing.
To make the balls you are going to need a drill to drill a hole through the center of the 24 balls. After you have drilled the holes in the balls take your nylon rope and measure and cut it into 12 20-inch pieces. It is suggested that you burn the ends of the rope so that they don't fray. Stick the rope through the holes and tie a knot on either side of the ball so they don't move. Put one ball on each end of the rope. You are going to need 6 ropes with 2 balls on each.
Once you have finished making the balls you are ready to play! Some play with each player on their own ladder, if you want to play that way you can follow these instructions again to build a second ladder or you can just use one.
on Oct 28, 2013 | Sport & Outdoor - Others
Btd 140 rfe chuck not spinning true
The usual reason for major wobble of the spindle is a worn gearcase. It can easly be replaced. Any good repair agent can do it. If you want to do it yourself. Simply remove the circlip holding the chuck sleve on then take off the washer, spring and balls. release the light unit from underneath and take off the locking block. The gearbox cover will then unscrew (but can be tight) I think it is lefthand thread.Check spindle for wear and lubricate the bush bearing in the new gearcase, then rebuild in reverse mode
Jun 17, 2012 | Makita 18V LXT Lithium - Ion Cordless...
I have drilled a 1 inch hole in my concrete basement wall. I cannot release the bit from the drill. The chuck won't turn by hand to release the bit.
Good Afternoon, Ladooudep55:
I hope you have got your bit back, but if not, remount the drill chuch onto the bit, and drill in forward without pushing the bit. If it still won't move, You can gently wobble the drill to enlarge the hole and retrieve the bit.
The other method is alternating light hammer taps with compressed air. It will make lots of grit dust.
If the hole around the bit is wet, you may have drilled into an iron pipe, if it smells it was the sewer drain. You will have to decide if you want to replace the pipe section or run an epoxy patch once you have retrieved the bit.
Chr
May 01, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
A pin hole in pvc pipe under jacuzzi what can i use
Self amalgamating tape wrapped several times around and well over lapped would probably do it. Just to be sure I would secure it in place with one or two 'jubilee' type hose clips (the sort used to secure radiator hoses on cars) would probably make a quick fix.
For a longer term repair you could try using fibreglass car body repair paste (the sort with fibres in it - not the smooth filler paste). However it will not still to pvc very well. The surface needs to be rubbed with a bit of glass paper to roughen it slightly and then degrease by wiping with a cloth moistened with acetone (nail polish remover would do) before fibre-glassing.
Feb 26, 2011 | Home
I have an old Delta D-220 drill press. While the chuck spins true, even at high speed, a drill bit will have a slight wobble towards the end of the bit. I tried many bits so its not a bent bit. Solutions? ...
You are right,but if the wobble is not too big to do drill jobs it can be used.Sometimes drill jobs need to be precise,so the you will need it just aligned.
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or go direct to this link.
Good price and service.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | Delta Woodworking Vintage Delta Dp 220 14"...
Spindle on myCTT drill has about an 1/4 inch of play; Is this to
Holy cow! I am surprised the thing has not come apart (exploded). 1000th of an inch is too much. In my opinion, it would be cheaper and less hassle to replace the unit entirely. I do kinda wonder though, how were you able to drill anything straight with that much play in the spindle?
Nov 09, 2009 | Drills
Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Oct 07, 2009 | Craftsman Drills
Back wheel assembly is wobbly
If the wheel wobbles it may be the cones are loose (these are the next bolts along from the nuts that hold the wheel on and they have a locking nut) so these need to be adjusted to stop any play in the spindle whilst still allowing free rotation of the spindle then the wobble should have gone .
Jun 23, 2009 | Huffy Raven 26-Inch Dual-Suspension...
Cutting cast iron soil pipe
Phil, I recommend a ratchet snap cutter as it will allow you to cut the pipe in a clean manner. These are available for rent at most major home improvement stores in the US. One can also rent one at a tool rental company. I rented mine for $35.00 the bulk of which was a deposit on the tool. Just a reminder when buying the coupling device ensure you ask for or get a 4 inch cast iron to 4 inch PVC coupling. A bit of vaseline will help you get the neoprene coupling to seat properly with the PVC if you encouter resistance. Good luck. If you need more assistance let me know.
Sep 25, 2008 | Plumbing
Drills Logo
66 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
