Question about LG WM-1832C Front Load Washer
Need casters - LG WM-1832C Front Load Washer
    Top Expert:
  • LG Master
  • 79,186 Answers
We are not a parts store buy you should be able to get these from the www.repairclinic.com
Posted on Sep 06, 2009
NEED ONE CASTER FOR AMCOR AF12000EH
From what I can see of it, the casters are a standard sort of design. Large hardware stores sell a range of these, and I'd start by taking off another caster for a match, and having a look in Home Depot or similar (I am assuming you are in the USA). If you have done that already with no luck, you will have to move on to a specialty oulet like
http://shepherdcasters.com/
Mar 02, 2016 | Amcor Heating & Cooling
I can not get the caster on the left side to adjust to specs. has new upper control arm and +/- 2 degree adjusterts and caster will not go below +5.5.
There has to be something bent. Lower control arm look oK? Any sign of fame damage? Spindle look ok? Caster is generally not a tire wear factor. However, the vehicle will pull to the side with most caster and least camber.
Jan 20, 2016 | 2004 Ford Explorer Sport Trac
Caster broken
Some caster wheels are a press fit on an axle. That's why they frequently fall off.
Feb 19, 2014 | Goldstar DH304 Dehumidifier
Does this chair have breaks?
This chair doesn't have breaks but it comes with casters that will hold it in place. Each caster, which should be placed on the floor where you want the chair stationary, is three inches by three inches. The casters are included with the chair/cammode.
Feb 16, 2014 | Generic Lightweight Portable Shower Chair...
Are there smaller, portable, air casters?
Yes. However they might not be your best solution. Portable air casters usually work best for very short distances and infrequent moves. This means that if you need more frequent moves or travelling longer distances, you will need continuous compressed air supply (high pressure nitrogen bottles), which would make the whole cost more than it's worth.
Dec 30, 2013 | Air Tools & Compressors
How do the wheels install
10. You will find four casters (Figure B) and a dolly (Figure C) with your wet/dry vacuum. Assemble as follows:
11. If the casters are not already installed in dolly, insert casters into bottom of dolly by placing stem of caster into holes provided. Ap- ply pressure and twisting motion until casters snap into place (Figure 1).
12. With cord disconnected from receptacle and tank cover removed, turn tank upside down so that bottom is facing up.
May 29, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Where can i get a set of wheels for my five gallon brute vaccuum?
http://www.shopvac.com/shopvac-accessories/Products/420-63-96.aspx
emailthispage.gif printthispage.gif 1" Dual Wheel Caster (Set of 4 6774200 casters with retainers) Catalog No. 420-63-96
Four (4) casters. Set of 4 Replacement Caster Wheels with retainers. This item is the replacement for the plastic, non-hooded casters shown. These casters you will receive are an upgraded dual hooded caster that are a perfect replacement but offer superior performance.
Four (4) casters. Discontinued. Order this item and we will send you an upgraded, superior dual hooded set of casters. A = 1-12/16" B = 1/4" C = 1-9/16" D = 3-7/16"
You can also look at your local Lowe's who sometimes carry a generic wheel.
Mar 07, 2011 | Shop Vac Brute 5 Gallon Bagged Canister...
Need replacement caster wheel unit.
I found them here:
http://pelonis.com/parts.htm
Feb 20, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Need replacement casters for a jenny lind crib, where can I buy them?
We carry a variety of replacement casters- check out our selection here: http://www.productsamerica.com/casters.html or call us at 800.205.9642 or 800.772.1041 for direct ordering assistance.
Sep 16, 2009 | Evenflo Jenny Lind Crib
Changing the dual axle on an Invacare recliner to lower seat
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
Jan 16, 2009 | Invacare Lightweight Tracer SX5 Wheelchair...
LG WM-1832C Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
