Question about Sony STR-DE545 Receiver
Sharp bursts of static
Loud static on all venues except for phono, which is fine. I have disconected all plug in in order to isolate the problem , no change, ran through the speakers same thing, help! Ed
  • 593 Answers
Phono is the only input that uses a low level input (mag) I bet it has something to do with the input processor.
Posted on Feb 24, 2008
No tv picture and intermittent audio
Check the cables and connections
Apr 13, 2014 | Tatung Televison & Video
Loud static burst at random times
Bose is proprietary. It could be electronic parts that are called capacitors.
Dec 09, 2013 | Bose & Wave& Music System
I have a marantz st100 receiver, and everything seems to work well with one exception. There is static in one channel that comes and goes, and sometimes gets quite loud. The problem follows the channel...
It could be a burned out resistor in the main power amp. Follow the channel wires from the speaker that is playing up till you get to the power amp. Look around for anything odd. Compare it with the other channels, as they are good.
Oct 03, 2017 | Marantz Audio Players & Recorders
Bose lifestyle makes loud noise like a build up of
If you still have the speakers that the TV came with hooked up try unhooking the wires to them I had the same problem and it fixed the problem, Good Luck!
Apr 10, 2010 | Bose Lifestyle 28 System
How do I fix bad static? Dell W3706MC 37 in. HDTV LCD has been fine and suddenly the sound has loud static on all sources. Is this a sound circuit failure?
Yes,loud static usually comes from bad isolation of sound signal path so it's probably a frayed cable or a loose jack. Or if you're unlucky some parts inside have failed.
Oct 26, 2009 | Dell W3706MC 37 in. LCD HDTV
Loud bang from speakers
i would suggest that you check the condition of the stylus, because the sound could be prouduced when the needle is lifted and the diamond tip is damaged so it makes a loud noise, normally a loud crack.
Nov 16, 2008 | Audio Players & Recorders
Low Audio
You need to connect the turntable to a PHONO input on your amplifier. Not all amplifiers have a phono input, if yours doesn't you need to get an RIAA pre-amp to plug your deck into & this connects to your amplifier.
This is because although the audio outputs on the turntable look the same as all the other components, they are very different. The signal has not been amplified up to line-level like tuners, CD players, tape decks, etc. You need to get this thin, weak signal boosted.
Your 3 options are:
* Connect directly to the PHONO input on your amplifier if you have one. If you don't:
* Connect deck to a RIAA amp (also called a phono stage) then connect to any input EXCEPT phono on your amplifier
*Connect the deck to a DJ mixer then hook the mixer up to any input on the amp EXCEPT phono.
Dec 23, 2007 | Technics SL-1200M3D Turntable
Sony STR-DE545 Receiver Logo
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
