Question about Epson Aculaser C1100 Printer
4 colour dots on printout but not 150mm apart
Hi Tigertail, I'm not sure if my problem is the same - portrait printout - groups of 4 dots but seemingly randomly printed, 15 sets on one piece of paper, 2 15mm from left hand side and the others 40 to 45mm from right hand side - please don't let it be the photo thing ?
  • karen778 Sep 06, 2009
    Hi Tigertail
    Thanks for the help, going down the page the gap seems to be 148mm, there are 5 groups of dots and they are repeated 148mm down the page but 1mm to the right ?
  • 163 Answers
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Posted on Sep 06, 2009
Printout
The scanning unit may need servicing nor replacement, if sure the catridges are Ok
Jul 13, 2013 | HP Color LaserJet 2600n Printer
Dear Sir, I ahd problem for the printer, Since it has been two weeks. I need to get it solve soonest. Caued we have data sheet to be printed. We need hlep now .Could you help us on this please. I have...
HI,
you better go for a laser printer's,Hp groups or canon group ,then it will be ease for you to get printout without trouble.
You didnt write the exact technical snag ,you were faced while taking out prints.
to print Data sheet ,even dot matrix groups printers are also convenient,
May 26, 2011 | Office Equipment & Supplies
Hi, my HP2600N colour laser jet leaves two 1cm wide coloured smudge lines length ways on all my A4 prints. The printer is getting to about 2 years old now so i'm fearing that some major part needs...
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Rest assure that the printer is fine and needs no major replacement.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 22, 2011 | HP Color LaserJet 2600n Printer
Ricoh CL7100- Black Dots on all printouts
What are the correct colour settings for optimum colour printing for Ricoh Aficio Cl7200
Apr 12, 2010 | Ricoh Aficio CL7200 Laser Printer
I have an Celestron advanced Series GT goto mount that does not turn on. I have taken it apart and looked at the circuit boards and power is getting to the switch, but I cannot locate any obvious loose...
Contact either a Celestron Dealer (customer service) or Celestron customer service.
http://www.optcorp.com/ a dealer
http://www.celestronlife.com/groups/all user groups for all Celestron telescopes
http://www.celestron.com/c3/support3/index.php?_m=tickets&_a=submit&group=C3 Celestron Support
Oct 31, 2009 | Celestron Advanced C6-S (60 x 150mm)...
We have just changed the photoconductor unit on our Epson Aculaser CX11NF printer. When we print or copy, we get coloured spots on the right hand side of the page
Oh-ho! The coloured spots are what is known as "traffic lights". To be sure these are the symptoms: You will have a black spot then a slightly larger gap then the three colours regularly spaced, the pattern will repeat every 150mm or so. If you print a black only page then only the black dot will appear, print with any colours and all four dots will be printed. It is caused by a tiny/slight scratch on the photoconductor (PCU) drum (usually caused by mishandling, a loose or foreign object inside the printer or even trying to print on stapled paper!). Polishing the drum using a very soft dry cloth can often help to get rid of the scratch, but remember to keep it away from any bright light as this will damage the sensitivity of the drum. The traffic lights will be in line with the scratch so concentrate your efforts in that area. Also, while the PCU is out, take a good look inside the printer for any loose or protruding objects, rotate the toner cartridges from above with the front cover closed (opening the front locks the cartridge carousel in position). I sincerely hope this helps as the only other remedy is to replace the PCU with a new one.
Jul 07, 2009 | Office Equipment & Supplies
Black dots on printouts
there is probably something on a drum, fuser roller, transfer roller, or primary roller. usually an easy fix for a copier tech, probably not for someone with no experience.
Apr 29, 2009 | Office Equipment & Supplies
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Apr 11, 2009 | Epson Aculaser C1100 Printer
Repeated cyan line across printouts.
Need to replace the cyan PCU. It is a user replaceable item. Here is a link to user manual:
http://www.ricoh-usa.com/downloads/manuals/printers/cl7000/manuals/CL7000%20Printer%20Maintenance%20Guide.pdf
Nov 12, 2008 | Ricoh Aficio CL7000 Laser Printer
Epson c1100 leaving coloured dots on paper
Looks like you are caught in a trap of your own making -using the wrong paper. You decide Expensive Epson repair or dump it and get get a cheaper printer. I really do not think there is a DIY solution. You could take a look at www.fixyourownprinter .com There may be an answer. Epson do a very reasonable swap out scheme for dead ink jets- I am on my third R-300- check them out - the 1st out of warranty R 300 cost £45 including delivery and collection of the dead one - the third came free.
Jul 09, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
288 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
