Question about John Deere Garden
JOHN DEERE STX38 RIDING MOWER. TOOK KEY OUT. CANT GET KEY TO GO BACK IN. CANT PUSH MOWER FORWARD OR BACKWARD. SEEMS TO TO BE LOCKED DOWN.
  • 426 Answers
Well if the transmission on the tractor is anything like one of a car or small engine mower it has a brake unit on it. which stops the engine from moving while off so that the unit will not move on you. The key is most likley your main and only problem. You would have to try to remove the cylnder, this may be hard since the key will not go back in, usually you need the pins to be aligned by inserting the key to remove the cylinder. I would try using a pick or flatened paper clip to try to realign the pins so that you can get the key back in, and once you have it back in, remove the cylinder, and replace it, or soak it in some p.b blaster and then graphite it once clean. you should graphite spray it once a season as part of your maintenance routine. anything else please ask.
good weekend.
Posted on Sep 06, 2009
John Deere SRX75 Riding Mower unable to push when placed in neutral.
check that there is not a system that when in neutral , the park brake is not engaged
Oct 14, 2016 | John Deere Garden
John deere stx46 won't move in forward or reverse
There is a handle on the rear of mower make sure it is not in the free wheel position. If so push it in and it should move. If not seek out an authorized dealer to test your tranny. Also check that your belt didn\'t break
Aug 03, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
John deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
May 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Aug 19, 2009 | Garden
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
Garden Logo
46 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
