Question about Pentair Minimax NT Heater
Minimax NT heater is knocking. Could it be gas
Minimax NT heater is knocking. Could it be gas pressure? Is there an inlet filter I can check to see if clogged?
  • 990 Answers
More often than not this will be the by-pass and thermal regulator. Both of these are inside the water manifold on the side of the heater. I will usually replace both if one is bad. If one is bad the other can become damaged and the labor and parts to do this are a big part of the job. Also check and see if you have a by-pass on the plumbing going to the heater. This will be a valve bridging the water in to and out of the heater. If you have one it should be 80-90% closed so it forces water through heater. If any of these are bad it will let water go past the heater and the water inside the unit will overheat and turn to steam and with no place to go it just expands and starts banging.
Posted on May 17, 2010
    Champion:
  • 246 Answers
Assembly valve need to be replace
Posted on Sep 13, 2009
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
Getting ERR message on my Pentair Minimax
make sure filters are clean then check to see if voltage on both sides of pressure switch if so check to see if voltage to ignitor if so ohm out ignitor should be about 78 ohm at 70 degrees if ok then see if safety circuit is ok then check to see if 24 volts to the gas valve brown wire and yellow wire
Jul 26, 2014 | Pentair Minimax NT Heater
Minimax nt heater pv led light is off on back of 6800 controller board
check pressure but check safety circuit then gas then ignitor and pressure switch
Aug 03, 2013 | Pentair Minimax NT Heater
Pentair Minimax NT 250k - ERR blinks 3 times
check pressure switch or tubing to it then gas and ignitor
Mar 22, 2012 | Pentair Minimax NT Heater
Minimax 400 heater not operational
what is ok on the water pressure? th heater need from 40 to 60 gpm in order to work properly clean the filter and let me know
Sep 10, 2009 | Pentair Minimax NT Heater
Pool heater won't kick on
check the gas line pressure; (if this was a homeowner installation you will not be able to check the gas pressure) dirty filters are the number one cause of heater malfunction. before you do anything else break the filter apart and clean completely and recharge with diatomaceous if applicable. also check the pump baskets and make sure there is no debris in the basket or blocking the impeller inside the pump. if this doesn't solve your problem call pentair tehcnical support
Jun 22, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Minimax NT Heater Logo
133 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
