Question about Samsung Eternity Cell Phone
My samsung eterntiy wont vibrate when i tap the screan as it usually should what should i do?
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
Samsung galaxy s2 will not charge
Could be a battery problem, ut is usually a problem with the charge cable or connector. Try a different charge cable, they are usually Micro USB connectors, and check if the power (MaH) Matches what your phone needs. Otherwise you might need to repair the port. Try this.
http://www.youtube.com/watch?v=q4e-5xkhvHA
Jul 22, 2014 | Samsung Galaxy S Ii 2 Sgh-t989 16gb...
Why does it only vibrate even when ringer is on?
You might try putting your finger to the left of the network fan at the top of your phone and swiping down, you should see a list of items like wifi,location, screen rotation, sound or other items like these. If you do then tap the sound icon and it will change from vibrate to sound or to mute depending on how many times you tap the icon.
Jul 08, 2014 | Samsung Centura - Straight Talk Wireless
Kenwood 616 not changing background image
i need help trying to find out what my samsung eterntiy sim code is any ideas
Mar 19, 2010 | Kenwood Car Audio & Video
My wife has just got a Samsung C3050 and wants to know how to turn of the key tones, also how to get a different tone notifying receipt of a text. She has swapped it for a C300 and is frustrated that the...
I know this post is late, however if you tap on menu, then settings then sound profile, then tap on the profile she is using (usually 'Normal') and maneuver to the bottom of the screen and tap on 'Volume and vibration' and go down to 'touch tone' and slide it to '0' then the key sound will stop. I hope this helps
Feb 06, 2010 | Samsung C3050 Cell Phone
When my samsung impression is on vibrate, and i get a text message it vibrates at least 10 times. how can i get it to only vibrate once?
1)tap on settings
2)next tap sound profile
3)next tap normal
4)then tap on the upper right side (the dialog box that says call) with the drop down arrow
5)choose message
6) then you can set it from there, you can change the setting of your msg alert type, alert tone, alert repetition, alert tone vol, and vibration pattern.
Jan 10, 2010 | Samsung SGH-A877 Impression Cell Phone
I accidently droped it into water and now when i turn it on it wont stop vibrating what can i do to stop the vibrations?
Usually the buzzing means the computer board is fried inside. You can try to change the battery and hope it is just the battery - but usually the constant buzzing means it is now R.I.P. Sorry
Jan 07, 2010 | Samsung SPH-A420 Cellular Phone
Even on silent, it vibrates. i want to stop vibration. this is samsung impression
1) go to menu
2) settings
3) sound profile
4) tap silent
5) tap on call alert type and choose mute and then tap on save.
6) then save.
Nov 02, 2009 | Samsung SGH-A877 Impression Cell Phone
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Eternity  Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
