Question about Kohler Electrical Supplies
I have a kohler generator that wont generate electricity but it will run? 4.50KM21-RV SERIAL 192809
  • 9812tbone Sep 06, 2009
    Actually I was told by my buddy that the circuit board is burt up and he is going to wire around it and we need a schematic. What do you think about that?
    The new board is about $2-300 dollars.
  • 138 Answers
The first thing you need to check is engine rpm if the engine does not rev up to approx 3250 then the generator will not self excite. Lug a voltmeter into your outlet and take reading if it doesnot generate try revving the engine and it should self excite. Once this happens leave your voltmeter plugged in and adjust engine speed until your generator output reads 125VAC. With this set the generator will self excite as long as there are no other problems. If this does resolve your problem let me know
Posted on Sep 07, 2009
    President:
  • 2,600 Answers
I'm taking a wild stab at this simply because it happened to me. The breaker button was tripped and was actually broken. Since it was broken, it wouldn't reset but it looked like it had, therefore engine runs but the juice was cut off from the panel.
Posted on Sep 06, 2009
I have a Kohler Confidant 5, model 5ckm61 generator in my RV, serial # 338225, spec# 101218. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depressed ....
The control board needs to sense a voltage coming of stator windings to complete the run circuit or else it will shut down. Check the stator and rotor windings for resistance and shorts
Oct 21, 2013 | Electrical Supplies
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Blown fuse (input fuse) on kohler generator when i push start switch
I have a kohler rv generator voltage shows 15 after starting it blows the fuse why?
Jun 11, 2012 | Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
What engine is in my rockworth generator?
i need a manual for a ( kohler RV Generator 4.50km21-RV Spec # 10111A plus need to know Motor Size Can any one help me out
Apr 14, 2012 | Electrical Supplies
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
I have a 1992 Itasca Toyota RV with a electric issue
Is there power at the gen? The transfer switch may not be transferring power over from gen. Check it at the gen first thing.
Aug 05, 2009 | Electrical Supplies
Electrical Supplies Logo
194 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
