Question about Brother MFC 240C All-In-One InkJet Printer
Fax printer and copy
I cannot get my printer and fax machine to be install
  • Anonymous Dec 10, 2007
    I have followed all the steps to install my printer;it takes a long time to complete the instalation. Is this normal?
  • 832 Answers
Nell,
did you run the mfc software (mfl-pro suite) first? Leave machine without connection to pc. The software guidesyou thru set-up and wil give you a info when machine has to be connected to USB.
In case you dont have the cd or you run Windows Vista you need drivers which you can download here:
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID=%7b2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8%7d&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top%2ehtml%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc240c_all&NRCACHEHINT=NoModifyGuest&prod=mfc240c_all&reg=us&c=us&lang=en
Install the drivers and AFTER that connect machine to USB
Posted on Dec 09, 2007
The network won't set up for the x464de
usually you must install net program on cd machine in your computer after than change your set up on your network.always to set up network for copy hard but after that you install cd program you can do it
Nov 27, 2013 | Lexmark X464de Multifunction Laser Printer...
Need ocr app for s415 lexmark
You can download the OCR software from the installation CD for your printer.
If you lost your installation CD, please contact our technical support team to get another copy.
Jan 25, 2013 | Lexmark S415 - multifunction fax / copier...
I not sure how to get faxes? my machine is a C309A scnaner and fax and printer
Does it freeze when you try to make a copy? If it does, it means there's something wrong with the scanning mechanism. Have a look see if you can spot anything that might be blocking it.
If you can copy fine, then there's something wrong with the drivers installed.
Aug 03, 2011 | HP Office Equipment & Supplies
HP J3680 Officejet shows scanner error, will not copy or fax
typically this is a software problem. Please check to make sure you have the correct and most up to date driver installed
Jul 21, 2010 | HP J3680 Officejet All In One Printer
I tried to fax from my computer using the x7170, but it only prints. I can fax from the machine. Is there another software I need, or driver? Thanks, Ken
Hello. Make sure that the fax software is already installed in the computer. There should be a fax object in Printers and Faxes/Printer/Printers and Devices(for Windows) or in Print and Fax(for Macintosh). If there is, when you send a fax from the computer, make sure to use the correct print object which is for the fax. If driver is not installed, reinstall the software.
Mar 07, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
DOES THE MACHINE HAVE FAX CAPABILITIES? DO YOU
No. They have print,scan and copy capabilities but no fax option is avail.
Dec 17, 2009 | Canon imageRUNNER 5000 Copier
Machine reboots
maybe it thinks it has a fax option..delete the panasonic then re-install. make sure you reboot the computer. Some software requires you to restart the computer.
Jun 27, 2008 | Panasonic Workio DP-2330 Printer
Brother MFC 240C All-In-One InkJet Printer Logo
77 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
