Question about Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer - Water will not stop running
Water overflowed the tub and did not stop until the machine was turned off.
  • Anonymous Mar 28, 2014
    the water from the washer comes out too fast and overflows the drain
  • 5,911 Answers
If the wash tub overfills without stopping unless the washer is stopped, this is usually caused by a defective pressure switch or loose air hose going to the pressure switch. The pressure switch is located behind the water level knob inside the console. It is common for the rubber air dome hose to come off and cause a washer to overfill. The console can be accessed the following ways:
If you have removable end caps, the will lift of by prying up from the ear of the console and pulling from the front. Sometimes inserting a screwdriver in the slot in the top of the end cap on the back of the washer and giving the screwdriver a slight twist can help to pop the end cap loose. There will be a philips screw under each end cap that will need to be loosened.
If the end caps are not removable, you will need to slide a putty knife under the front corner of the console where it meets the top of washer on each side and push in to release the retaining clip that holds it in place.
Once you have the console loose, you can flip it up over the back panel to its resting position. Use care not to damage the small plastic hinges that hold the console to the washer.
With the console in its resting position, examine the pressure switch. It will be a round plastic switch located on the left hand side (sometimes located in the center) of the console. There will be an electrical connection and a rubber hose attached to it. More common than not, the rubber hose comes off. If this is the case, reattach the hose to the small nipple on the switch. Use care not to break the nipple. You can take a small zip tie and place it over the hose where it is attached to the nipple and secure it snugly to help keep the hose in place. Do NOT over tighten as you can damage the nipple. The zip tie creates enough resistance the keep the hose from sliding off from vibration over time.
If the pressure switch hose is still attached, double check your electrical connection. If the connector is intact, replace the switch as a last resort. If you can provide me with your model number (located under the lid along the wash tub rim) I can get a part number for you and let you know how much the switch would cost. I hope this helps you.
Posted on Dec 09, 2007
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
My Sears series 80 washer fills till it is overflowing and doesnt shut off water flow, it was overflowing onto floor this morning, it is full to the rim now, and wont drain or do anything when it is turned...
The usual arrangement is there are 2 electrical water inlet valves, one for Hot and 1 for Cold. These valves are turned on by the timer, and remain on until the water level switch turns them on, and allows the washer to then run. It sounds like this water level switch is bad. This switch should be in the panel above the top of the washer, and has a rubber/plastic tube that goes toward the washer drum. It is also possible that the rubber tube is off or blocked. (if the water inlet valve is stuck open, turning the washer off will NOT stop the water).
Good Luck,
Aug 17, 2012 | Kenmore 23822 Top Load Washer
Kenmore 80 series won't agitate
You will need to check you water level switch. Sound like it is bad or has something clogging it. You can test it like this. Find the tube that runs from the back of the level switch down to the outer tub. Unplug it from the tub. Now turn machine on so that it will start to fill. Now blow pressure into the tube. If it does not cut the water off, you have a bad switch. I would think it's bad. I see them about 5 ir 6 times a week.
Please rate solution if helpful.
Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
Apr 17, 2009 | Washing Machines
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
115 people viewed this question
Sal De
 Brian Main
Brian Main
