Last year the machine worked without leaking, this is a new problem. The machine is a few years old and I don't use it very often. The tank does not leak when I fill it and place it on the counter. Once I put the tank into position, the water practically flows from the bottom of the unit, this is more than a slight leak. Everything else, suction, brushes, are working fine. I haven't tried to remove the panel on the bottom to check the hoses, inside. Any ideas?
I had exactly the same problem with mine. This seems to be a known problem. You need to buy a new tank, it's the only way to fix it. I got my replacement from Amazon.com; problem solved, works great.
carpet steamer will wash but not vacuum up waste water , cleaned out reserve tank and made sure...
(More)
carpet steamer will wash but not vacuum up waste water , cleaned out reserve tank and made sure underneath was clean
The upholstery attachment will not slide down and gets stuck because the space is tapered and the...
(More)
The upholstery attachment will not slide down and gets stuck because the space is tapered and the connector is not. Is there some other way of attaching? Brute force does not work.
The middle brush on the 5-brush block fell out of our Hoover steamvac F5914900 as well. We put it...
(More)
The middle brush on the 5-brush block fell out of our Hoover steamvac F5914900 as well. We put it back in and it just keeps falling out. We have only had it a little over 2 months. I will try to get it fixed under the warranty, though I'm cautious that they'll consider this a "wearable part" and charge us for the repairs. We'll see!
