Question about HP W2007 Desktop Monitor
I'm looking for the diagram of the power supply
Hello
I'm looking for the diagram of the power supply for the HP w207H monitor.
The lightning had broken out the power line.
I try to repair it.
Many thanks
best regards
  • 114 Answers
Next time use a surge suppressor
Posted on Sep 13, 2009
Open lcd 17 power supply 5volte ok 13 dimming
Hello.
First of all you need some electronic repair experiance,
You have to disconect all f the power supply that going on 5v(rgb processor in moust cases)and 13v in most cases ccfl inverter(back lite ) with his driver.than have to mesure the voltages.
-Replace the capatitors in 13v line.
if the problem persist try to replace the diode one for 13v with one for 5v,they should be the same type.and check the voltage 5v and 13v.
if the problem is still on 13v look for the problem on the 13v line.
Feb 08, 2014 | Samsung LS19CMYKF/EN Monitor
My hp L1506 Lcd monitor power suply is out can i repair it
Yes, if you have knowledge, circuit diagram etc.
I suggest you take it to an electronic repair shop, power supplies are dangerous if they are not fixed properly.
Aug 02, 2012 | HP 15" L1506 LCD Monitor Silver/Black
Samsung syncmaster 215tw will only display faint blue screen-no images.
Check for a failure of the capacitors on the power supply board. This is a common problem with these units and its a very easy repair. Here is a link to a repair guide for the SyncMaster 214T which uses the ame power supply board so the repair information would be the same for the 2 units.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Jun 07, 2012 | Samsung 215TW SyncMaster 21" LCD Monitor
KDS Rad-7c struck by lightning
try to use another monitor power cord if is can turn on, otherwise immediately contact your monitor manufacturer to repair such device since it was struck by lightning
Dec 06, 2011 | KDS Radius RAD-7 17" Flat Panel LCD...
Lightning strike near house. Power surge came through phone line and ethernet cable. lost modem, computer, time machine, house security system, and HP Officejet 6310xi. When printer is connected to power...
From your description the HP printer is damaged beyond repair, when a lightning strike occurs it also went through the power supply affecting the main board and destroying ic's and other parts. It is more than likely the interface cord from the computer to the printer also took a jolt hitting the printer from both sides finishing off any chance of recovery, you would be further ahead replacing the item.
Jul 06, 2011 | HP Office Equipment & Supplies
HP f1703. After a power outage, when computer is
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 19, 2009 | HP Pavilion F1703 17" LCD Monitor
My F1903 will come on for a second or two when I turn on my computer, but then the screen goes black. When I can see the screen, everyhing looks fine. Does anyone have any ideas? Also, it started going off...
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 27, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Compaq presario c300 wont turn on at all
Looks like a bad motherboard ,have you tried another power adapter the one that connects to the wall socket.
The motherboard could cost over $100 ,chepaer on Ebay or you could take it to a Compaq/HP service center and ask for a quote on the repair.
May 13, 2009 | HP Compaq Motherboard
Have an HP LCD Monitor with a broken on/off switch.
j1hoo2, You will just have to go to YOUTUBE and search for things like::: lcd monitor disassembly or lcd monitor repair, or bad caps in lcd monitors, or repair of monitor SMPS/INVERTER power supplys. Yes!!! I have seen a couple of vids that show how to unsnap the rear plastic cover from the front bezel. That is the hardest part to do after removal of the monitor PEDESTAL. I'm louie12fix on fixya, or lmistyrel@ aol.com
ps I've also heard that really dull table knives may work and also an old credit/swipe-card might work also.. I mean did an elephant step on the monitor on/off button???? Come-on, their not supposed to FAIL !!!
Apr 24, 2009 | HP L1520 15" LCD Monitor
HP W2007 Desktop Monitor Logo
126 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
