Question about Refrigerators
Water dripping and freezing in bottom of freezer
Water is dripping from somewhere and freezing in bottom of freezer. We chip the ice away and then it comes back. Frig is old so not sure if it can be fixed or it is worth fixing.
  • Mike Smith
    Mike Smith May 11, 2010
    I am sorry , but the problem you refer to , did not pass the required information into your request such as model number . If you would care to elaborate and reply with that information , to this post , then Fixya experts will endevour to help you further .
  • 32 Answers
You might have a compressor that are pumping insufficient, a capilary tube that is partially blocked, a gas leak somewhere that can also cause the problem because of shortage of refrigerant. and that is why you will have a spot that is not igetting cold enough that is causing water condensating on that spot and drippng down where your condensor is colder.
Posted on Sep 07, 2009
Water is accumulating & freezing @ bottom of freezer ice maker has been removed water to fridge has been turned off still, water coming from somewhere & freezing
This is what it sounds like to me. There is a drain hole for the defrost water to drain down to the "drip pan" If that hole in the drain pan is clogged. Then when the defrost system melts away the frost in the cooling coils. Every 6 or 8 hours. The water will accumulate in the bottom of the freezer compartment and turn into ice. This is a very common problem.
The solution.
Put the food in the freezer and fridge into coolers and pack with Ice. Get the 99 cent coolers at the supermarket and buy some Ice there too.
Shut the fridge down and open the freezer door. chop out the Ice in the bottom of the freezer compartment, but not in the drain area directly below the coils. that will be hard to get to and you may damage the fridge if you just chop away.
To speed up the process, get some hot water in a glass and pour it into the area below the coils
(that should be a solid block of Ice as well). If you cant get to this easily, just wait for the fridge to thaw out naturally.
After it has thawed out, you should be able to locate the drain tube in the bottom of the small tray
below the coils. Stick a flexible piece of wire, or pipe cleaner or something of the sort into it to completely unclog it. So when you pour water into that tray, it immediately drains out completely.
into the "drain pan" located below the freezer compartment in the base of the fridge.
I hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Maytag MSD2756GES Side by Side...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Water is dripping from freezer into refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Apr 13, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
The bottom freezer portion of my gladiator freezerator forms ice
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Ice make not making ice, water dripping in Freezer
need to replace coolant in the freezer. Either that or electricity cuts out. check cable
Aug 24, 2009 | GE Refrigerators
Water in freezer
Most refrigerators today are ice maker ready. If the plugs that were installed in the cabinet and freezer compartment that are used to plug the "ice-maker ready" holes are removed, then moisture seeks it's way into the freezer and freezes.
You will need to replace the plugs to prevent this from happening. Do not use tape to cover the holes as most tapes are not watertite. You should be bale to find replacement plugs at your nearest home center, or from the manufacturer of the refrigerator.
Jan 15, 2009 | Whirlpool Refrigerators
Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
