Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi ws55511 hd is projecting a distorted view on screen
  • Mitsubishi Master
  • 3,459 Answers
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 06, 2009
How do i get rid of purple horizontal distortion lines?
This is a older model and likely the first generation of HD set made by Mitsubishi---where the HD input is on rear (DTV?) ARE THERE TWO JACKS MARKED H sync and V sync?
If they are there set needed an external box made only by Mitsubishi for for later HD use.
Apr 12, 2012 | Mitsubishi VS-60111 60" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
My mitsubishi ws55511 remote does not work and
The front buttons need to be replaced. I would replace them all due to no being able to tell which ones are the bad ones. It should fix the problem.
The part # of these Tactile switches is 432P089010. Mitsubishi's parts department phone is 800-553-7278.
The two front grill covers pull off and the front plastic housing unscrews from the front.
Hope this helps,
Sky Assoc
Oct 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Double image on picture model # ws55511
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 24, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have HD 1080 and the images are sterched at the
You should be able to change the aspect ratios so your images arent distorted.
Jun 15, 2009 | Televison & Video
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
PROJECTION TV COLORS DISTORTED
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Dec 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
