Question about Insignia IS-LCDTV32 32 in. Television
Can not turn on, remote not worked too - Insignia IS-LCDTV32 32 in. Television
  • Insignia Master
  • 5,138 Answers
Power supply Pcb Part# 667-L32K5, But before you buy Board Look to see if you have any bad or Leaky capacitors they are 2200uf 25v 1000uf 16v if they are puffed up on Top they are Bad for capacitors call Mats 1-800-628-1118 and for Part Try UED 1-800-648-6657
Posted on Dec 09, 2009
I have a sanyo hdtv with integrated tuner and the
(Some universal remotes do not work with newer televisions, so the following instructions may not work)
Turn on the television.
Hold the 'CODE SEARCH' button for 3 seconds until the LED light is solid red.
Press the 'TV' button; the LED will blink once and remain solid red.
Point the remote at the TV and slowly and repeatedly press the 'ON/OFF' button until the TV turns off. (The LED will blink once each time you press the 'ON/OFF' button.
Once the TV turns off, press the 'ENTER' button; the code will be stored in the remote and the LED will turn off.
The remote should now work with the TV; test it out to see how it works.
(The remote may be too old for your TV; if the above instructions don't work you may need to get a newer remote.)
Sep 03, 2014 | Televison & Video
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
TV won't turn on with remote, but remote does work.
If the control buttons on the side/back of the tv works then you can verify the remote works.
Take a digital camera(turned on) and point the remote at the lenses. Press the remote buttons and look for flashes on the camera's lcd.
If the remote works then the remote receiver on the set may be bad and need to be repair/replaced.
Feb 13, 2011 | ViewSonic N3252w 32 in. LCD Television
Remote hardly works.
austinater
Have you replaced the batteries in the remote with fresh batteries? If you have, then you may have IR interference that may be causing the intermittent loss of function on your remote. Try turning all components off, including any lights, to see if the remote works. If it does work, turn 1 component on at a time and trying the remote to see if it works. If the remote doesn't work after turning a component on, that is probably what is causing the problem. If it still doesn't work after turning all components on, you may need a new remote. I hope this helps.
Ray Calo
DISH Network
Sep 22, 2009 | DISH Network IR Remote Control
Remote Control does not work
press and hold tv button till light stays on enter 4 digit code if code is entered properly light should go off then turn tv off with remote if it does try to turn on if it does your in good shape if it doesn't turn on try diff code 0062 0204 0207 0183 0226 0288
Jan 27, 2009 | Philips Universal PH301S Remote Control
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Will not recognize a remote
Olevia has no remote code like all the other brands... it is too new.  the universal remotes were made without Olevia codes because there weren't any.  i'm not sure if/when this will change, but i can't wait.  right now we mostly control the TV volume by using the stereo remote........
Aug 25, 2008 | Olevia LT32HVM 32 in. LCD Television
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Touch Screen and Remote Problem
My remote stop working. I replaced the 2 AA batties by still does not work
Oct 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
Insignia IS-LCDTV32 32 in. Television Logo
18 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
