Question about ASUS K8U-X Motherboard
On my ASUS K8U-X inly Windows3.1 works ok. Whindows Xp crashes immidiately after installation. Why?
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    Have you checked with Microsoft to make sure that this model number motherboard is compatible with windows XP?
    President:
  • 2,600 Answers
The bios on your systen does not support that operating system
Posted on Sep 06, 2009
Cant find p35-153-11z9 driver
Tere isn't a separate driver for the Realtek 8201CL 10/100 Mbps Ethernet Controller. The driver is part of the chipset software & should have been installed when you installed the Asus motherboard support CD software. (Asus K8U-X).
Double check your bios settings. Check that the onboard LAN controller is set to Enabled. See page 2-19 in your Asus manual.
Link to Asus; http://support.asus.com/download/download_item.aspx?product=1&model=K8U-X
Link for manual; http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8U-X/e2010_k8u-x.pdf
Realtek wants people to use Driver Detective to help in finding drivers from RealTek, see the link posted; http://www.driversupdated.com/exact/realtek.php
(I do not know what the these mean from your post, P35-153-11z9)
If your LAN is set to enabled in the bios, try reinstalling your Asus CD software, (Chipset drivers). If the drivers still fail to install it is possible the LAN controller is defective.
Sep 02, 2011 | ASUS K8U-X Motherboard
Hello when i install windows my sata hard dont detect. my main board is asus k8ux hard is western 1.0tera
You are probably installing windows XP
This requires that you install the textmode sata raid drivers as you install windows
http://support.asus.com/Download.aspx?SLanguage=en&m=K8U-X&p=1&s=20
Download the RAID driver and expand it to a floppy , CD or USB drive that the computer can recognise
(USB is better)
When you install windows, at the prompt for installing other drivers press F6 and let it find the raid drivers, if it finds them, it should then recognize your hard drive and you can install windows XP
Jul 26, 2011 | ASUS K8U-X Motherboard
Asus K8u-x, please i need ethernet controller. for my driver give me a link..... im waiting
the driver should be on the disk supplied by your isp internet service supplier
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click update driver also will be the options to disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
hope this helps
Jan 09, 2011 | ASUS K8U-X Motherboard
I need drivers for network adapter Asus k8u-x "WINDOWS 7 only"...pls HELP :(((((
Hello the asus site is here:
http://usa.asus.com/Motherboards/AMD_Socket_754/K8UX/#download
But here is only drivers for xp.
My suggestion is to buy a network card compatible with win 7.
Good luck
Nov 11, 2010 | ASUS K8U-X Motherboard
I have a k8u-x motherboard.. my problem is i cant install winxp in it because it doesnt detect any hardisk during the setup. All my floppy drives are damage as well as my floppies. Is there any way to...
Your trying to install windows 3.1 or 98 ? I have never seen Windows XP or newer on floppy disk is why I ask. That will not resolve your problem though. If you are sure you have the hard drive installed and connected with at least one of them set to Master, if you are installing 2, You may need to enter Bios and have it auto detect the Hard Drives in the Bios. If the Bios doesn't recognize the Hard drive or you have 2 hard drives and one isn't set to Master it won't matter what media you use you won't be able to install anything on the hard drive.
Sep 08, 2010 | ASUS K8U-X Motherboard
I lost the C D for my motherbord asus k8u.x plz
Please go to the site below and download the drivers for your motherboard.
http://www.howtodrivers.com/model550881.html
Also for future follow the link below
Search for Drivers Online
Jul 09, 2010 | ASUS K8U-X Motherboard
PNY VCG84512SPEB GeForce 8400GS (ASUS K8U-X)
I have no idea why you would go from an agp to a pci. Agp has like 8x the banwidth of pci.I'll assume the agp slot went bad. If you can get into bios before you lose the display,change the display from agp to "init pci first",save & re-boot. See if that works,then when in windows install the drivers right away. If that doesn't work, during boot at the splash screen, press f8 & select "safe mode" with networking. This should let you get into windows so you can remove the old agp drivers,then re-boot into safe mode again & install the new drivers. Then re-boot normal & you should be ok. If not,that board has a big problem.
May 14, 2010 | ASUS K8U-X Motherboard
Asus K8U-X motherboard,which ram memory , and processor support?
hi..for this mother board model asus K8U-X only same brand Processor u can oly use.Like if u use Sempron made by AMD only AMD Processor for that board.Memory support is DDR1 PC400 1gig up to 2gig...good luck and Have a Nice Day..
Jun 14, 2009 | ASUS K8U-X Motherboard
P35-153-11z9 mother board need network adapter driver ?
Hi Paul, there isn't a separate driver for the Realtek 8201CL 10/100 Mbps Ethernet Controller. The driver is part of the chipset software & should have been installed when you installed the Asus motherboard support CD software. (Asus K8U-X).
Thanks for using FixYa Paul!
Need more help? Post here.
Mike
Mar 14, 2009 | ASUS K8U-X Motherboard
ASUS K8U-X Motherboard Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
