Can't get speakers to work properly
I can't get speakers to work, don't know if they are hooked up correctly. I have been through the device manager and all states they should work or are working properly. Can't get anything but faint static when at full volume, can only here with ear to speaker and both project the static.
  • Anonymous Jan 05, 2009
    how do i get labtech speakers to show up in device manager
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hi ! Frizz
happy holidays!
Well, you need to see if you can put in the green conector back in your PC, a pair of headphones and put a CD and see if you get sound, if so, then your sound card is fine, and is your speakers the culprit, if no, then is something with your sound card, of conections. check that please.
Carl
Posted on Dec 10, 2007
We are hooking the speakers up to a new computer and we don't have the software
Threre is no software for these speakers. This is the installation guide:
http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf
Make sure you have the proper sound device activated and volume turned up. If after speaker set up, you have no sound, get into your "device manager" and click on the box next to"sound, video and game controllers"(on right) and, righy click on each device that shows in the list. You should see "disable". If you see "enable" click on that and exit. You should have a speaker icon in your taskbar, lower right of screen. Right click on that and then on "open sound mixer" and, adjust your volume.
Jun 14, 2011 | Logitech Z313
All I hear is a hum, the speakers aren't working and I know that they are hooked in correctly. Just want to make sure.
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 19, 2011 | Altec Lansing VS2621 Speakers
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
Apr 15, 2010 | Logitech X-240 Computer Speakers
I just hooked up my Labtec LCS-2420 speakers to my new computer and can't get any sound out of them. I can get the cheap ones that came with the computer to work, but not the Labtec. I hooked them up to...
if its a 6 channel connection its a little tricky try reconnecting your speakers that has a green connections. try playing a music while troubleshooting the connection...hope this helps..ITTech7574
Aug 29, 2009 | Labtec LCS 2420 Computer Speakers
My emachine desktop does not give sound when i play videos.
Please cross check the audio driver is installed or not from Device Manager
My Computer(right click)-> Properties-> Hardware->Device Manager ->Sound,Video & Game Controller(expand it)-> See if any thinh with yelow ? symbol.
If it is please install the audio driver from manufactures web site.
Jul 31, 2009 | E-Machines eMachines Desktop PC
Speakers not working
Did you try other speakers (that you know work correctly)?
Did you ensure the speakers were plugged into the correct place (wall and back of computer)?
What does your Device Manager say for this device? To get there, right-click on your My Computer icon, select Manage. From there, look in the left hand column for Device Manager. If you select that, It will display information about devices installed on your machine. Look for a red X or a yellow exclamation point.
Let me know what you find or if trying what's above solves your issue.
Derek
Mar 06, 2009 | Dell A215 Computer Speakers
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
How do i know where the grren cord goes, there is 2 different green slots and i tryed both of them
Hi, itryed
Well, first thing first! you mean, someone Format your computer? if so. Just see in device manager if the person install the correct drivers for yous specific sound card . (device manager) if not install them from the CD that is drivers for your computer. (sound)
then put the cables and check!
that should do the trick
Nov 19, 2007 | Ozaki DT-500 3-Piece Speaker System...
1,016 people viewed this question
 Grubhead
Grubhead
