Question about Air Tools & Compressors
I have a Porter Cable air compressor model CPLKC7080V2. Air leaks from the pressure switch and aftercooler safety valve and the pressure switch before the compressor reaches 80 lbs pressure. I replaced both the pressure switch and the aftercooler safety valve, and the new parts leak as well. Obviously not the right diagnosis on my part.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
I believe you have a head valve or piston ring problem. The parts you replace are suppose to leak. It is a safety feature that doesn't allow the motor to burn up before the pump warms up. Kind of like a soft start feature. If you look on the breakdown part number 107 Kit Valve Plate is what you need to inspect. Sounds like your valve plate is either worn or damaged. If you go into the pump you will have to get part 103 also which is a gasket kit. Or you can try to salvage the old gaskets.
If the valve plate is ok you will need to inspect the rings that go around the pistons. Some times you will get one that gets brittle and breaks off scarring the cylinder. Look for these two things, I am pretty sure one of them is the problem with your compressor.
Posted on Sep 08, 2009
Porter cable 6 gal pressure switch. safety valve blows when tank filling
Depending on the pressure in the tank when the safety valve releases,the problem is likely your pressure switch. If the pressure is at or above 160 psi when it blows, then the problem is the switch.If the pressure is lower, then it is likely a faulty safety valve. There are about 8 versions of this machine. check on dewalt service net for the correct part. you may need to check ebay if the part is nla thru dewalt.
Jul 06, 2014 | Porter Cable C2002 150 Psi 6 Gal...
Porter Cable Pancake compressor builds pressure, but will not shut off when max pressure is achieved. Pressure switch is NOT the culprit.
Most P/C compressors shut off at 150psi. If the pressure switch is bad, the pressure will rise until the safety pops. If the safety is not opening, then most likely the cylinder / piston ring is worn to the point that pressure will not increase past safety range (cylinder could be scratched near top ). If cylinder and piston are ok, then air is leaking somewhere (check all joints with soapy water). Good luck
Sep 17, 2013 | Hitachi EC12 Portable Electric 2hp Air...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
6hp 25 ga. porter cable compresser, keeps running -blows, blowout valve, compresser works good new pressure switch? thanks ,scoop
Pressure switch can be adjusted to lower pressure (most are set between 125 and 150) however could be faulty safety valve if safety open below 165psi. Some things to check. Safey has pressure setting stamped on side. Check range of safety and compare to tank pressure when safety opens. Check that pressure switch contacts are not welded (unplug unit and remove cover to switch, look for contacts thru side of switch). If you suspect that switch is faulty, buy universal switch from ebay or other suppliers making sure of pressure range and fittings. Good luck
Mar 08, 2011 | Porter Cable Air Tools & Compressors
I have a Porter Cable pancake air compressor CFFN 250N manufactured in 2004 that has an air leak. Pressure can only get to 80 PSI. Checked all the connections and found no leaks. Finally took the cover...
There is a check valve where the line goes into the tank. The purpose of this valve is to keep air from coming out of the input line. This valve is likely the culprit and it is leaking out of the unloader. The unloader is actuated by the electrical switch when the compressor shuts off, and it relieves the pressure on the line so that the pump is not under load when it tries to start.
Feb 02, 2010 | Air Tools & Compressors
I have a porter cable 4.5 gallon 150psi air compressor when it gets to 150 psi the air release valve opens
That is what the relief valve is set at, you need to
either increase the pressure on the relief valve or
reduce the pressure on the pressure cutout switch. Stephen
Sep 06, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Extra fitting on my Porter Cable?
CANT FIGURE OUT WHAT YOU HAVE. IF ITS ON THE REGULATOR - THE REGULATOR USUALLY HAS AN INLET, OUTLET, GAUGE PORT AND A PLUG IN THE OTHER SIDE IN CASE YOU NEED TO MOVE THE GAUGE. SOME MANUFACTURERS PUT SAFETY VALVES IN THIS PLUG PORT. IF THIS DOESNT FIX IT GIVE A LITTLE MORE DETAIL. IS THERE ANYTHING WRITTEN ON IT. HOPE THIS HELPS, JODY
Apr 26, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Cut off switch problem
The pressure switch will trip off when the compressor reaches the rated setting (usually 120 ~150psi). If the compressor keeps running untill the safety pops releasing air (usually about 160psi) then the switch is most likely problem. I use SquareD switch from WWW.Grainger.com. However if the compressor keeps running but never pops the safety and only reaching around 90 to 100psi, then you could have several other issues including: leaking fittings (check with soapy water), worn cylinder and piston (on oilfree compressor examine cylinder from below and look for scratches), leaking valves on oil type compressor. Please email with your finding and any questions Good Luck
Jan 28, 2009 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Air Tools & Compressors Logo
218 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
