Question about Philips 55PP9401 55" Rear Projection Television
How doi adjust convegence manually on phillips 55pp9401
How do i adjust convergence manually on phillips 55pp9401
  • Anonymous May 03, 2009
    Lost the remote and need to do the convergence manually
    Genius:
  • 1,694 Answers
Order service manual from partstore.com ..........
procedure is complicated..............T.
Posted on Dec 10, 2007
I need a blue tube for my phillips 50p8431a..can anyone help
Posted on Dec 18, 2007
Intellisense adjustment not working
It will not work if the convergence circuit is not functional--it is indicated here it is phillips 55pp9401?
Mar 24, 2012 | Philips 55PP9401 55" Rear Projection...
How do I adjust the manual convergence? I am in the settings, but my TV is not letting me adjust anything. I chose the "reset to factory" choice, but that didn't fix the red/green shadows
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
Don't have remote is there another way to line up colors I've already changed the convergence chips but not the resistors
Chances are the new ICs have failed since the 6.8 ohm resistors werent changed a phillips will almost always blow one or two of the 6.8 ohm resistors and if new ICs are installed without replaceing the resistors the new ICs are usually destroyed by the blown resistors. You will need the original remote or authorized replacement to adjust the convergence properly.
May 06, 2011 | Philips 55PP9401 55" Rear Projection...
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
Convergence problem
convergence problems occur alot in these sets. First question you always ask is the picture bowed in at top and bottom. or even on sides. go into customer menu and go to setup. do you have convegence option. if you do not go read fl231 problem in tips and tricks. this could be simple and inexpensive. However it can also be one of three cuicit boards. Next quesiton if you got convegence option does the autoconvergence work. if not how far does it get. then if that doesnt work does manual convergence of blue and red work do the cross hair move at all. if the do or only move one way. it might be convegence amp if not then might be convergence power board.
Sep 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
55pp9401 convergence problem
try aligning them using the yoke control rings.
sometimes the alignment is so far out that you have to adjust the magnet rings instead.
Feb 25, 2008 | Philips 55PP9401 55" Rear Projection...
Phillips 55pp9401 red and green not converging even after using itellesense
Replace convergence IC's STK392-110 mounted on large heatsinks....I use upgrade STK394-160E = CZ 01341 Hitachi #.
Let me know if you have ??'s.......................T.
Oct 27, 2007 | Philips 55PP9401 55" Rear Projection...
Phillips 55PP9401 Convergence Problem
STK392-110 convergence IC's upgrade to STK394-160.....
I use Hitachi brand part # CZ 01341 ... change both.......
Check for dis-colored resistor (s) = replace with exact value...
Please respond............T.
Aug 12, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
556 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
