Question about Dryers
It does not dry the clothes even tho it goes thru the motions
  • 430 Answers
If no heat then likely the element. However if it gets hot and then heat shuts off, you could have a defective humidity sensor or blockage in the lint trap or vent pipe if it is warm but never finishes it`s cycle,.
Posted on Sep 06, 2009
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
The heat is not hot enough to dry clothes half load
A dryer either heats or not heat . You have a vent blockage or vent hose kink . Pull the dryer out and remove the vent hose . Dry a load and see if it drys ok . If so , check the vent if it goes thru the wall to outside , or if goes up thru the ceiling , may have to get a cleaner ( line and brush ) at Home Depot .
May 02, 2010 | Whirlpool LGB6300 Gas Dryer
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Will not play a dvd or cd even tho battery is fully charged
Issue with your optical lens. Try cleaning it with proper tools such as soft dry cloth. Try using non scratch discs after cleaning it.
Jan 17, 2010 | Televison & Video
MODEL PBSR353EWOWW. Dryer is functioning but...in
One or more of your heating elements is probably out.
I have a repair album with photos and a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2010 | Dryers
The programme goes through the motions of a tumble dry but the clothes are not drying
Washer Dryers have a built in seperate heating element with a blower fan to dry the clothes. Your problem could be a simple thermostat/overload reset or there could be more sinister problems. This would be hard to decipher without looking at the machine itself.
Jun 16, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Takes a long time to dry clothes
You might want to clean out the exhaust hose where it goes thru the house. Also vacuum inside the unit to if you havent done so already. Let me know if this helped
Apr 27, 2009 | Dryers
I 450 printer sends command to print but, no print on paper, paper goes through the printer as tho' it is printing but no print
Check your ink cartridges. Even with ink inside, the heads could dry up and not allow new ink to penetrate. Take a dry cloth (rag, not something you wouldn't want stained) and gently wipe it over where the ink shoots out of the cartridge. If you barely get a streak on the cloth, try dampening up the cloth and gently wiping the ink cartridge to see if it loosens up the ink flow.
If there is already plenty of fresh ink coming out of the cartridge, you might have a problem that isn't worth fixing. Repair costs compared to buying new are very similar these days.
Apr 01, 2009 | Canon i450 - Printer - color - ink-jet -...
I have an MP460 printer. Suddenly it won't print. When I try to print a document from Word, the printer acts like it's printing--goes through the motions, spits out a page, but nothing is on that page,...
  1. Open the front cover of the printer and remove both cartridges.
  2. Moisten a clean, lint-free cloth with water and gently wipe the gold nozzle area.
    Warning!
    Wipe the nozzles of the color cartridge in one direction so the colors do not mix.
  3. To dissolve dried ink, hold the damp cloth against the nozzles for about three seconds. Gently blot and wipe dry.
  4. Moisten another section of clean, lint-free cloth and gently wipe the gold contact area.
    Warning!
    Do not wipe the nozzles and contacts with the same section of cloth.
  5. To dissolve dried ink, hold the damp cloth against the nozzles for about three seconds. Gently blot and wipe dry. Let the gold-colored areas dry before you reinsert the cartridge into the printer.
  6. Reinsert the cartridge and repeat the nozzles test.
May 17, 2008 | Canon Office Equipment & Supplies
Dryers Logo
44 people viewed this question
Top Dryers Experts
