Question about Acer Aspire One AOA110-1588 Notebook
My Acer keeps on checking the file system on C: for consistency--after it is finished I get the screen to start windows normally and it will start the check all over again
  • 477 Answers
Hello, looks like your laptop is in a loop. try to start in safe mode.
Safe Mode
As your computer restarts but before Windows launches, press F8. (after bios screen)
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
if it start try to restart your computer and see if it starts correctly.
if that doesent work boot with your windows xp CD and run repair mode.
Instructions for Checkdisk.
try to restart your computer and see if it works.
get back to me if non of this instructions works and I will help you.
Posted on Sep 06, 2009
  • 69 Answers
Have you try to check volume errors ?
From My Computer, right click the Drive (c:) then Properties, click Tools tab and then click Check Now, shut it down and restart.
Or you can even click Defragmentation, but it will take a long time.
Be sure to back up your impotant files before do Defragmentation, just in case.
I have an acer aspire one aoa110, when i turn it on, the acer intro comes, followed by the windows intro and then a light blue screen appears stating that says "checking file system c: the type of...
Your hard disk is problem, there is two possible things that make you get that message. First your hard disk is full and there is a problem that windows cannot find specific file, that file maybe damaged or erased or moved to other location. Second your hard disk is about to die :). When and if your successfully finish repairing itself, try to download form the Internet program : " Hard disk sentinel", that program is free of charge. When you finish downloading install it and run. The program will show you in what kind of shape is your drive or drive's if you have more than one. In the filed on top find configuration and than preferences open and click on the " Load at windows startup", uncheck it. When program shows the shape of your hard drive or drives it will also show you estimated time when is predicted it will die. If you have BAD Sectors and program shows you a lot of red fields its time to backup your file and replace that drive.
Oct 13, 2017 | Acer Aspire One AOA110-1588 Notebook
Problem opening Windows
Usually a sign of Hard drive problems, boot up in safe mode if you can.
Right click on C: drive, properties/tools/error check and let it do a full scan with automatically fix errors chosen.
You may want to back up as much as you can if you manage to get into safe mode
Jul 16, 2010 | Acer Aspire One PC Notebook
When I turn on power it says windows did not start menu, then it will show windows xp starting, then it goes to a screen that says one of the disks needs to be checked. After it's finished checking the...
After the disk-check has finished, your computer *SHOULD* restart "normally", and should *NOT* re-issue the "need to check" message.
If it does repeat, you could have a "dying" disk-drive.
Take your computer to a qualified technician, to backup your files, replace the disk-drive, re-install Windows, and reload your files from that backup.
Jun 23, 2010 | Acer Aspire One PC Notebook
Hello, I have had my Acer Aspire One netbook since January and it worked fine until now. It tries to boot but then I get this screen: > Checking file system on C: The type of file system is FAT32. One...
First of all, boot from a windows cd and proceed forward until you reach the format options, and check out if there's any problem with the c: drive or not. Sometimes this happens when the drive is corrupted. If it's ok then run windows repair setup and restore it again. In case this ins't possible, (if you have multiple partition on the system), i would suggest you to install additional windows on another drive/partition, boot from it and check if c: drive is ok or not.
If unfortunately the drive is corrupted, there's no other option for you to boot without formating c: drive, but you can run a quick format and recover the files (if there are important files saved on your system[C; drive]).
I would wish to know after all these.
Good luck.
Thanks for using FixYa.
Jun 21, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire t135 pc desktop locks at splash screen
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is usually a hardware problem.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Apr 27, 2010 | Acer Aspire T135 PC Desktop
Can only start acer pc in safe mode -window consistency check.
Microsoft indicates that this issue can be a hardware failure.
http://support.microsoft.com/kb/137539
You can try using only 1 memory module if system has 2, or try reseating if it only has one. If system works normally with 1 module, replace the other
Mar 15, 2010 | Computers & Internet
Your windows installation has become corrupt first reset your bios to failsafe default settings then reinstall the operating system delete and create the partitions and forma properly before fresh installation of operating system
Aug 19, 2009 | Acer Aspire One AOA110-1588 Notebook
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
Oct 12, 2008 | Acer Aspire 3680 Laptop
Acer L100 comp wont start past the windows loading screen
If I were you I would reformat your PC. In short words reformatting you Delete everything from the pc, the reinstall the OS(Operating System). Once the process is done, your PC is alot faster, and fresh. What happens to most people's PC it gets bogged down, and you go along time without cleaning it it will crash, just like a car.
There are hidden folders within the OS such as the prefetch where files are kept to help you boot problems faster, but the prefetch gets bigger each day, and isn't really needed.
To clean the prefetch you would go to Start>Run>type "prefetch" without quotes, once it opens the folder delete ALL files in it, a shortcut is to click any fil inside the prefetch, and press "ctrl+A" that will select all the files and now simply press Delete, and confirm Yes.
Something else to help maximize your system is to do a "disk clean up" access that by going to start>all programs>accessories>system tools
I hope this helped you maintain a better system in the future, if I were you I would go ahead and do the reformat then use the tips I just gave you to keep your system in shape.
Also another top make sure you keep your system clean of threats,(malware,spyware,adware,etc...) I would recommend Norton or Mcfee, I go with www.grisoft.com and www.eset.com, another one I like is www.trendmicro.com its up to you which you choose.
Good Luck!
Oct 15, 2007 | Acer Aspire L100 PC Desktop
Acer will not open any programs
your pc should check the system files on boot up and will keep asking until you allow it to do so. If it doesn't run through a system check and just stays at 0% then there is a serious fault either with the operating system or your hard drive is failing. You will need to repair windows with your installation disc as if you cannot get into windows you will need to restore your system. I am assuming when you say you cannot open up programmes, you mean you cannot get to your desktop.
Apr 16, 2007 | Acer Aspire 3000 Notebook
Acer Aspire One AOA110-1588 Notebook Logo
407 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
