Question about Canon PIXMA MP460 All-In-One InkJet Printer
Won't Print Any Ink
I recently replaced the empty ink cartridges (both color and B&W) and now it acts likes it printing, but nothing shows up on the printout, or is VERY faint. It plain won't print black or magenta colors. I performed the nozzle head cleaning, deep cleaning and alignments functions, to no avail.  I've near given up. Any suggestions?
  • Anonymous Dec 18, 2007
     Wont print color. comes out partially black
  • 3 Answers
Well? how old is your printer?. does your printer head is new?
reason why doesnt have printout:
1. the unit doesnt recognize the printer head:
solution: turn off the unit and turn it on again.
2. Defective logic board.
solution: replace logic board.
3. Defective printer head
solution: replace printer head
4. Clog printer head
solution: wash the printer head with water..make sure to dry
before you install it to the printer.
5. Defective purge unit.
solution: replace purge unit.maybe it wont suck ink because of the loose or broken springs under caping of the purge unit..
6. inktank.
solution: check the lips of inktank maybe it much shallow so it
wont touch the nozzle of printer head..
you need to cut the edge of the lips of inktank so it will touch
the nozzle of the printer head.
Posted on Dec 21, 2007
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Cannot make the printer work after I changed the ink cartridges?
You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
2. Release the Power button.
3. The 'Tap 41' diagnostic test print should print.
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Sep 01, 2013 | HP Deskjet F2480 USB 2.0 All-in-One Color...
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
Do all cartridges need to have ink in for the printer to work? I have replaced the black ink but blue one is showing empty & it will not print black only
It should print "Black" only. You have to setup printer options, chaginf from colour tab too Blackl?
You naughty person, were's your replacements! Huh.
Nov 14, 2009 | Epson Stylus D92 InkJet Photo Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
133 people viewed this question
old marine
old marine
