Question about Photography
The lock on my (mother's) Marco Polo suitcase was locked during travel and I don't know the combination... Help!!!
SOURCE:
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
SOURCE: suitcase number locked combination forgotten
how can i open my forgotten combination samsonite suitcase
Posted on Oct 09, 2010
Obertelli
  • 3006 Answers
SOURCE: I have just bought a
You have two options:-
1. Try every possible combination. Although there are 1000 of them it's going to take less time than you think as you won't need to go all the way from 000 to 999. usually for a three digit lock it takes less than five minutes and shouldn't take more than a maximum of about ten minutes.
2. You can try to hack the combination. All similar locks (including four or five tumbler versions) can usually be opened in less than a minute when you have the knack. Pull the lock apart as if it had the correct combination and keep the tension on it. One of the tumblers will be harder to turn than the others so start with that one. Keep turning until you fell a definite change in resistance on one number and then repeat with the next most difficult to turn tumbler. On your lock you only have to do this twice, the third and final one will just be a case of turning until the lock springs apart. Don't expect to perfect the trick instantly, but after a few goes you'll definitely get a feel for it and then be amazed at how useless and insecure most combination cable locks are. An experienced thief can hack them in easily under 30 seconds.
Safe and happy travels.
Posted on Jul 09, 2011
elitecgdwolf
  • 744 Answers
SOURCE: My samsonite suitcase unfotunately locked without absence of my knowledge during travel .now i am unable to open my suitcase.please help me. My mob no-***********
We do not have anything to do with opening suitcase ***********
Posted on Dec 02, 2015
Our suitcase is locked, and we forgot the combination. how can we reset the combination for our TSA approved luggage?
resetting the combination is only practical if the suitcase is open as the reset tab is located inside where it cannot be tampered with when locked.
if it is a set of dials lock a locksmith could help you.
regards,
Mar 25, 2018 | Luggage & Travel
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
How do I reset combination lock on Beverly Hills Polo suitcase?
With only 3 digits trial and error should get you there in just over twelve minutes, or approximately 500 tries...good luck! Use a system and keep track.
Feb 20, 2016 | Locks & Locksmithing
Hartmann suitcase. How do I open Presto lock with 3-digit combination?
Look for my tip on opening luggage with combination locks in this listing.
Nov 27, 2015 | Luggage & Travel
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
Presto combination lock on a suitcase will not open
Jan 14, 2009 | Extensis Suitcase X1
Forgot my combination to my sansomite suitecase
a local lock smith can help but by now you have busted the hasp
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 07, 2007 | Impact 800 Tripod
Photography Logo
Top Photography Experts
Steve Allison
Steve Allison
Ekse
Are you a Photography Expert? Answer questions, earn points and help others
