Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Center bolt of the agitator would turn to get it open.
I want to fix my washer but somehow agitator bolt wuld not come loose. I tried and tried and tried but nothing seems to be working. What are my option? Appreciate help.
    Problem Solver:
  • 18 Answers
It is probably reverse thread, so you are probably turning the wrong direction.
Posted on Sep 06, 2009
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
Should you be able to turn tke adgatator by hand with ease? it sound the washer makes when adgatating is not the same it made in the past and it seems to be slipping.The washer was new in 2005 or 2006.
Your agitator dogs are stripped out. Pry off the top lid of the agitator. Reach inside with a pair of pliers and pull the plastic tab loose. Take a 7/16 socket wrench and a extension to remove the bolt inside. Pull up sharply on the agitator to remove it.
Take the center piece holding the rubber dogs out of the agitator. Replace the 4 tear shaped dogs and re-install the agitator.
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 100.92380200 upper agitator not turning
Just fixed mine. You will need an agitator repair kit. It comes with cover seal, bolt seal ratchet pieces and thrust plate for the bottom of upper agitator. Remove fabric cup and cover underneath. Remove bolt and upper agitator. Simple fix. New parts have instructions to repair. Get the correct model number and buy it from an appliance parts place. Around $20.00 retail.
Jun 15, 2009 | Kenmore Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Need to remove agitator on kenmore series 70
Follow these steps for removing the agitator on a Kenmore:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Sometimes this is a dispenser cup that simply pops off.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Carefully remove the auger (upper portion of the agitator) and set aside.
  5. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
Note: Try to keep all the parts assembled while doing this. In particular, the auger. There are small components inside. In addition, when reinstalling the agitator DO NOT over-tighten the center nut. This can restrict agitator motion and may cause damage. Tighten until snug.
If you have questions, please let me know. I hope you find this information useful.
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Noisy/loose agitator
remove the top piece of the agitator. this is a dispenser. then remove a cap that is at the center of the agitator. there is a bolt there that is holding the whole agitator. remove the bolt and you can pull out the whole agitator. be careful in removing, the thing could just separate to pieces and you may have a problem assembling it again.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Washing Machines
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
I have a Whirlpool Model# LSQ7030LQ0 washing machine. The washer is making a lot of noise and the agititator seems loose and is flopping around as it turns. If I grab on to the agitator I can stop it...
This "MAY" be an easy fix,
I have seen the main bolt that fixes the agitator to the drive shaft come loose.
If you can imagine the agitator as a cone, the top point of the agitator is a cap that should pull or clip off. If so, using a long extention shaft and a socket set, you should be able to tighten up the bolt.
Good luck and post back results
Jul 08, 2008 | Washing Machines
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Apr 15, 2008 | Admiral AW22 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
