Question about Polar CS200
Battery replacement polar cadence sensor CS 200
Polar sucks, I'm going to Cateye
Posted on Jun 17, 2010
  • 4 Answers
Unfortunately that battery is sealed into the cadence sensor unit and unless Polar has recently changed the design you will need to purchase a new sensor unit from any bike shop which is a Polar dealer.
Posted on Sep 20, 2009
Testimonial: "Thank you very much for your assistance.Your advice is much appreciated and prevented me from damaging the unit. "
Weslo Cadence 200CS Speed Potentiometer
Check the value written on the pot. You can use any value which is near to it. You will get it in any electronic spare part shop.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 22, 2012 | Exercise & Fitness
Its stoped reading the cadence sensor
First check your settings and make sure that cadence is turned on. Then:
#1) check to make sure that your cadence sensor has not moved and is still within 1-2mm of the magnet on the crankarm.
#2) make sure you still have a magnet on the crankarm.
#3) if #1 and #2 are good, does a little red light come on (body of sensor) when the crankarm magnet pass the sensor.
If all these things have been satisfied and you still do not get a reading, then you have a dead battery and you need to replace the sensor.
Dec 05, 2010 | Polar CS100B Cycling Computer Heart Rate...
I have no speed or trip distance showing, cadence is normally ok. also my watch strap has broken and because it is glued on i cant get it fixed!
Since your Cadence is working then there is a problem with the actual speed/ distance sensor. First make sure that in your settings you have speed turned on. If so then...
1) Your battery may be dead = Replace CS sensor
2) The distance of the sensor and magnet is not set correctly = make sure magnet on spokes and sensor are within 1-2mm of each other.
Polar can fix the strap, you need to send into an authorized service center. They replace the entire strap unit. If you send into Polar to get the strap fixed, then you can send in the sensor unit as well for diagnosis if you want. But if #2 doesn't fix, then it's #1 and they will just tell you to buy a new one anyway.
Nov 29, 2010 | Polar CS300 Cycling Computer and Heart...
The speed (and worst of all distance) was droppping out now and then also the heart rate would hit 200 when rolling down hill. I think I have fixed this problem by leaving the phone at home. I've ridden...
2 Seperate issues:
Heart Rate - The CS200cad uses a coded transmission for the HR, When you have a HR that spikes that high, it is because for some reason the signal has not coded correctly. Here are a number of ways to help with that issue.
1. Make sure you have good contact between your chest strap and your skin.
2. Make sure the Heart rate sensors on the strap are wet. Or use a conductive cream to improve contact.
3. Make sure the strap is on correctly. Up high on the chest just under breasts, Polar symbol centered on chest and upright. Strap tight enough to keep from slipping
4. If the strap is older, make sure it is clean. Salt can build up in the strap.
5. If the strap is over 2 years old consider replacing.
6. Check Battery
For the Speed/ Distance - Same sensor (front) make sure that the magnet on the wheel is within 1-2mm of the Fork sensor. The magnet should align in the middle of the sensor, with the sensor just slightly angled into the magnet. When the magnet and sensor have a good signal a small red light will flash and you may hear a click when the wheel is rotated. If none of this works you have a low battery and will need to replace that front sensor.
Nov 21, 2010 | Polar CS200cad Cycling Computers
I have a weslo cadence 200 cs treadmill. I changed the batteries but the display keeps blinking 0
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
May 20, 2010 | Exercise & Fitness
I am looking for the Owners Manual for a Weslo Cadence 200 cs Treadmill...can you assist?thanks Carol
go to iconservie.com click on manual input this info CADENCE 200CS (WLTL1901)
May 19, 2010 | Exercise & Fitness
Cannot get my new cadence(WIND)sensor to work. will aparently teach. Any ideas
No reactions to any buttons:
Reset the training computer by pressing all the buttons simultaneously for two seconds until the display fills with digits. Press any button and set the time and date in Basic Settings after the reset. All other settings are saved. Skip the rest of the settings by pressing and holding STOP.
Polar Cadence Sensor W.I.N.D.
To activate the cadence sensor in your training computer, select Settings > Features > Shoes/bikes > Bike
1/2/3 > On > Cadence > On.
Teach new sensor? is displayed.
• If your sensor is already taught, select No.
• To teach a new sensor, make sure that there are no other cadence sensors nearby (40 m/131 ft) and then select Yes.
After selecting Yes, Start test drive is displayed. Rotate the crank a few times to activate the sensor.
The flashing red light indicates that the sensor is activated. Completed is displayed after the
teaching has been finished. The training computer is now ready to receive cadence data.
To return to time mode, press and hold the STOP button.
Good Luck,
Techjoel
May 08, 2009 | Polar Cadence Sensor W.I.N.D
Polar CS200 Logo
3,110 people viewed this question
Top Polar Cycling Experts
kirkjw
Level 1 Expert
mcgsp
Level 1 Expert
Ngoro
Ngoro
Are you a Polar Cycling Expert? Answer questions, earn points and help others
