Question about RCA F25654BC 25" TV
My RCA TV guide words is blurred but the
My RCA TV guide words is blurred but the picture is clear what could I do to fix the words so I can read them
  • happy98329 Sep 07, 2009
    I tried what you said and backed the sharpness down but it did not help and there is nothing on the back except a cable connection. What would cause just the words to be blury and the picture to be just fine?
  • 93 Answers
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Posted on Sep 07, 2009
Testimonial: "I will get someone to check it out. Thank you."
  • Jim Clark Sep 07, 2009
    this problem is normally caused by the sub brightness (G2) set a little high. If your adjustment control is not visible from the back of the set, then you will have a qualified person to adjust it for you
I had the same problem if it isnt just the sharpness then adjust both the picture and sharpness afterwards you might want to adjust the brightness
Posted on Sep 28, 2009
Tv picture is blurred
YOU MUST REPLACE YOUR CONVERGENCE IC S
COST 400 DOLLARS
Jun 03, 2010 | RCA P52926 52" Rear Projection Television
RCA P56812BL, Flickering Static like lines
Check all inputs and tuner, that you can, and report back.
Apr 19, 2010 | RCA P56812BL 56" Rear Projection...
Certain aspect of my sanyo tv are very blurred
This problem requires adjusting the Focus on the flyback . Turn the tv around and look for adjustmen slots on the back. If you can see them, use a nonmetalic small srewdriver and slighty adjust the top or left one. Be careful, it is the high voltage area
Sep 15, 2009 | Sanyo Televison & Video
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Blurred words
I have a hard time to vision that it is just the words, is the picture blurred also? If you are inclined, you have to take the back cover off. With a medium to small INSULATED screw driver you will see a big transformer that has a HIGH VOLTAGE lead going to the picture tube. There should be one or two black plastic screws on it (hence the insulated screw driver use) adjust one or the other to see if picture improves. Will not take much adjustment, but must take CAUTION as not touch the metal part of the screw driver, we are talking 15 to 32K volts. Naturally the tv has to be on to do this.
Jan 18, 2009 | RCA F25654BC 25" TV
Double words and blurred picture,
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Nov 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
RCA F27442 27" TV
1) Ask what the part location on the board is = IC301 for example..
2) Provide service #
3) Could be LA7612N
4) If they were not blowing smoke,why didn't they give you a
six digit RCA part # ??
....................................................T.
Nov 09, 2007 | RCA 32V420T 32" TV
Picture Blurred
If you head a pop then your color wheel may have gone out. You need professional support to get this replaced.
Aug 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
236 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
