Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
On/off/remote switch :could not turn on TV - Insignia I-LC23Q1 23 in. HD-Ready LCD Television
  • chercheur_04 Sep 06, 2009
    INSIGNIA FLAT PANEL TV
    MODEL IS-TVHD30 , 2005/0CT /PRODUCT
    COULD NOT TURN ON TV EVEN USING PUSH BUTTON OR REMOTE, ONLY RED LIGT INDICATOR
    IS THERE FUSE OR ... POWER SUPPLY PANEL BAD
  • 430 Answers
I think the remote sensor board has been damaged. Please change the curcuit board of the remote. This will help.
Posted on Sep 06, 2009
  • 10,594 Answers
That means Power Supply board seems defective and requires replacement.
Please local TV tech for fix or let me know if you need further info.
Thanks.
I have an emish tv box the remote switches it off and on if I press it after about 5 seconds. But if I switch it off with the remote i have to use switch on back of box to switch back on
DIRECTV - Support: Your Remote Control
www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
DIRECTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On ...
Program the remote for your TV - Fiber Help
support.google.com > ... > About the remote control
GoogleThe Google Fiber remote control is not designed to fully control external audio equipment. ... Press and hold the button on the original TV remote that you want to program on the Google Fiber remote. If the learning works, the TV power button on the Google Fiber remote blinks twice ...
Dec 26, 2015 | Televison & Video
Turn on without remote control
If the TV was switched OFF by remote control for the last time, you can't switch it back ON, without its remote control.
Just try this. Unplug the TV from AC mains wall socket. Wait for at least 5 minutes and plug it back. Switch it ON by its front panel power ON/OFF switch. Just press any button [Ch UP / Ch DN or Vol UP / Vol DN] Sometimes this might turn ON your TV.
Jun 02, 2012 | Televison & Video
I turned tv off with remote, now it will not turn back on. i have tried remote and button on front of tv.
Check the remote with new batteries. If it do not work, remote control has the trouble. You can't switch the set ON by its front panel power switch, as it has been shut down by remote command.
Mar 31, 2012 | Symphonic WF20D4 TV
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
I lost the manual and i dont know how to program it please help its an older direct tv remote?
10 Steps to Program Your Directv Remote
1. Turn on television.
2. Locate the switch at the top of your remote that allows you to toggle between receiver, auxilary, and TV modes. Slide switch over to"TV".
3. Hold down MUTE and SELECT until a small green light at the top of the switch blinks twice.
4. Enter code 9911.
5. Press and release the CHANNEL UP button repeatedly until television turns off.
6. When TV turns off, press SELECT.
7. Next, press the power button. This should turn the TV back on.
8. With television on, press and hold down MUTE and SELECT again until the small light blinks twice (same as in step 3).
9. Entercode 960.
10. Slide switch back over to "DTV". Your remote is now ready to use!
Jul 01, 2010 | Philips DIRECTV R15
Tv doesn't turn on with remote or the switch?
tv won't turn on manually nor with the remote
Jan 23, 2010 | LG Televison & Video
Sometimes the on/off switch doesn't work and we haven't been able to program the DirecTV remote to turn the TV on and off. We did discover that the original Toshiba TV remote will turn the TV off and on....
Could have a bad power switch or a bad ground on the switch itself. Will the original remote work to on and off the tv every time? If not you may a bad filter cap or two near the horizontal deflection.
Oct 10, 2009 | Toshiba 32D46 32" TV
Remote won't work and power switch pushed inside the television
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
May 15, 2017 | Sharp 25N-S100 25" TV
ON/OFF
turning off mute with no remote on a rca reciever
Dec 23, 2007 | Televison & Video
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
