Question about Ovens
Oven not heating properly
I have a Kenmore gas oven model # 36275708001, the glow coil lights at approx 36 seconds, i get flames (blue) about 2 and a half minutes later. It takes longer than usual to preheat and the oven is not maintaining the correct tempature. Please help
  • shryee Dec 08, 2007
    I am not sure where the burner coil is, how do you replace this
    so, you don't think its the igniter
  • 138 Answers
I think the burner coil is damaged or needs to be replaced. Check it if its damaged then you should replace it then it will work surely at definite time.
Posted on Dec 08, 2007
  • KALPESH PATEL
    KALPESH PATEL Dec 08, 2007
    It should be done thru some authorised person only
  • KALPESH PATEL
    no ignitor is different thing it work is to start only! else depends upon the burner coil
Trouble shoot oven
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 26, 2015 | Whirlpool Ovens
Hot surface igniter will glow and put out a flame but is not a blue/orange flame
First you need to get a nice blue steady flame to prove to the ignition module there is flame. Check you orifice and bypass tube.
Feb 22, 2014 | Lincoln Impinger 1116 Gas Oven
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
Oven won't stay heated, clicking noise like its trying to ignite, and gas smell.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Ovens
It doesn't turn on - no ignitor glow, suddenly
Hi and welcome to FixYa. I am Kelly. Without a model number we are pretty much shooting from the hip here. Having said that it takes all of the following to make the oven burner light:
1. Gas pressure to the gas valve and good solenoids (2 ea)
2. Power to Oven control and selector knob set above min temp
3. Over Temp sensor closed
4. Temp control "thermocouple or thermistor" functional
5. A functioning ignitor
So if you have power to the unit... and we assume the oven control is working.. suspects are:
a. Open ignitor
b. Open flame sensor
c. Open over temp sensor
d. Thermocouple or thermistor (depending on model)
e. Open coil on gas valve
Determining which of the above has failed is performed with an Ohm Meter.
If there is more that we can do for you just respond here.
Thanks for using FixYa.
Kelly
Apr 02, 2010 | Magic Chef 9122 Gas Single Oven
Kenmore oven doesnt bake
Can I assume that you determined that the bottom burner flame is burning properly? To do this, remove the oven bottom insert. The flames should have approximately 1" of blue cone and should burn with no yellowing tip, if on natural gas. (A small yellow tip on the end of the outer cone is normal with most LP gas.) The flmaes should not lift off the burner ports. If the flame is lifting, gradually reduce the air shutter until the flame stabilizes.
Go to the following website for your particular manual.
http://www.hammerwall.com/Manuals/Kenmore/Description/362.75585890/Kenmore%20Free%20Standing%20Gas%20Range%20Owners%20Manual/L0522834/
Feb 16, 2010 | Kenmore Ovens
Oven will not ignite, it is approx. 8 yrs old. 2 years ago the ignitor was changed for a similar problem. Everything works on stove even the broiler. Very dissapointed in the GE profile since I have had...
Jim your ignitor has gone bad once again.
You can turn off the gas supply,remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Place a clamp on amp meter over one wire of the ignitor and turn the control on for bake. If the ignitor does not glow at all. It is bad. If it glows and reads 3 amps or less on the amp meter it is still bad.
A proper functioning ignitor will light and re-light the burner in 45 seconds or less.
Jan 01, 2010 | GE Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
    Hi
    If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
    The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
    The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
    The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
    The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
    But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
    If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
    If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
    One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
    There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
    The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
    Could be a bad spark wire or broken electrode.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Sep 10, 2009 | Kenmore Ovens
    Oven burner doesnt light
    Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
    Hope this helps and good luck.
    May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Ovens Logo
    93 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
