Question about Sony VAIO PCV-RS724G PC Desktop
Power supply for aspire x1700 rating 100-127/220-240 Vac burt out
I need to buy a replacement online or from london
    Problem Solver:
  • 18 Answers
Ebay :D
Posted on Sep 07, 2009
Cd drive in my acer aspire x1700 doesn't open
You are going to need a paper clip. Look fo a small hole next to the switch. straighten the paper clip and put it in the hole in the center. carefully push to activate the mechansium to open the door. Then you can troubleshoot the door. Turn off the computer then pull the power cord from it. Open the computer case find the power cable to the cdrom/dvdcdrw and push it in to make sure you have good connection. If it still doesn't work after this then you can get a new drive for less than $30.00 (usd)
Hope this helps,
Terry
Nov 16, 2012 | Acer Aspire Pc Minitower X1700
My acer x1700 doesn't power up the power supply
Check your CMOS battery make sure its in tight and is not drained. also check the power switch cable from the power button to *********** board, that is the most common issue i see in my shop daily. and of course the power cord i would switch that out as well bad power cables are also very common.
May 30, 2011 | Acer Computers & Internet
I need replacement psu for acer aspire x1700 slimline tower
to be honest, the X1700 is a weak computer, you should NEVER buy slimline desktops, the power supply is going to cost more than the computer, being that it is a special type, you cant just buy it in a store, having to replace some myself, i can tell you that a decent used PC is around $150, and you can still put some of the hardware from the slimline into the used PC such as the hard drive, cd drive, and memory. Best of all, a full sized unit can be fixed relatively easily and for a lot less since most parts are interchangeable
May 06, 2011 | Computers & Internet
Power supply specifications to replace it
The original power supply in your desktop is an industry standard unit, 220 watts. You can purchase a power supply online or at your local computer store like Best Buys. Most power supplies being sold now are 300-500 watts, but the dimensions are standad.
These should work.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Acer Aspire X1200 Desktop PC - Athlon X2...
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
I have an acer aspire 47202 and it wont turn on
Here are a couple of simple things to try:
  1. try removing the battery, plugging the computer in, and starting it again. If it starts, you likely have a battery problem. To verify that it is a battery problem, reinstall the battery and try starting again.
  2. verify that the power supply is plugged in. also verify that you have the right power supply (perhaps you got the wrong one at friends ...)
  3. most power supplies have a light, do you have a light? If not, you need to buy a new power supply. You can buy a universal supply at any store that carries computers. Be sure that it has a wattage rating of at least what your old supply had. Also be sure that it has the voltage that you need. You can buy a replacement on ebay or at your manufacturers web site.
May 27, 2010 | Acer Aspire 4720 Notebook
I have replaced the power supply on my Acer Aspire X1700 computer but the new power supply acts exactly like the old. When I plug it in and turn it on the "Power Supply On" voltage goes from 5 VDC to 0 VDC...
When you have this problem on this PC, do not replace the power supply or the motherboard until you have first tried pulling out the video card. When the video card fails it can cause the x1700 to not power up. Pull the video card and see if it will power up without it.
Mar 09, 2010 | Acer (56.04145.901) (5604145901) Power...
I need to replace an A-Top ATC-250u. 115/230V - 7/4A 60/50MHz. I have found some to buy online but most of them have 3.5/5.5A or similar. Can I buy one that has a hight Amp rating on it and be safe? Say...
The ATC-250U power supply is a 250W supply based on the combined wattage rating of each output adding up to 250W... so increasing one output current means another has to be reduced to remain a250W supply... newer computer power supplies are 400W, 600W and even 850W. The newer supplies regulate using the 3.3V supply as a sense. The ATC supply has no 3.3V. It uses the 5V supply for regulation which means the current must be a minimum or 3A, but is rated to a 25A maximum (125W). The 12V is rated up to 10A (120W) and the other 2 outputs make up the other 5W.
Oct 21, 2009 | A-Top (ATP250-AT) (ATP250AT) Power Supply
Power conversion from UK to US
You need to check the rating plate on your power supply
If it was bought in the UK it will be set for 240v 50 hz
The US power supply will be 110v 60hz the supplies are not switchable re power input.
Jul 15, 2009 | Acer AOA150-1690 Aspire Notebook
Europe-to-usa power supply problem?
Hello Sarah, I brought mine in Europe too and found out that they are rated for 220 VAC while in the US you will need a 110 VAC power adapter so if this is your case you need to buy a replacement.
Jul 30, 2008 | JBL CREATURE II Computer Speakers
Sony VAIO PCV-RS724G PC Desktop Logo
683 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
