Question about Insignia 42" LCD Flat-Panel HDTV
Philips 50" tv will not pick up remote signal
Remotes are working but no response from tv
Even tho we change settings on Phillips flatscreen Model 50pfp5332, if we turn it off and back it' shows it's RETAIL SETTINGS. We do not have the original manual and would appreciate your help........
Posted on Sep 12, 2009
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
My philips 42 lcd will not respond to the oem remote or dish network remote. Both remotes are good
Click here at Philips firmware support center seems like this could be a firmware problem as Philips is known for in the TV repair trade. Download the latest version upload too your TV via connect card or USB see if this clears this problem. If not then its probably the infra-red sensor in the TV which is not working and needs to be replaced. Also be sure there are no parental locks which could influence remote control response...
http://tvtechwork.webs.com/
Oct 18, 2010 | Philips Televison & Video
Sylvania tv has stopped recognizing commands from remote.
Use some windex on the pickup on the front of the tv. It's a little dark spot, either round or square that picks up the signal from the remote.
Jan 17, 2009 | Sylvania 6427TE 27" TV
Remote will not work on tv
I need a remote that works with my television and I need to know how to take the close caption off
Jan 16, 2009 | Philips Magnavox 20MT133S 20" TV
Philips RC4318 Remote Issue
SOLVED!!!! Make hard reset of the remote control:
1. Five seconds Mute & Menu buttons 2. Press Select untill four lights comes up, exept TV 3. Press OK That's it! Get your remote control as a new :)
Sep 14, 2008 | Philips 50PF9630A 50 in. Plasma Television
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
Remote control
Just to make sure you have the correct remote, please match the part number you received to the part number in the link below (this is the original direct from Philips for that model).
50P8341 Original Replacement Remote
If the remote is correct, then you may have a problem with your IR remote receiver that is located on the TV set. This part however has been discontinued.
Mar 27, 2008 | Philips 50P8341 50" Rear Projection...
Help pleaz
1- make sure that the batteries are new and installed the right way (follow the diagram under the batteries).
2- if you threw out your manual download a copy at www.retrieve.com
Mar 15, 2008 | Philips Magnavox 20MC4304 20 in....
Lost remote
Buy an original remote or get a new DVD player. I would never suggest to my worst enemy the purchase of anything from Philips. The lack of support which you are experiencing is deliberate. Don't reward them with another sale.
Aug 25, 2007 | Philips Magnavox 27MS343S 27" TV
Insignia 42" LCD Flat-Panel HDTV Logo
163 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
