Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
Samsung SGH I 780 Touchscreen not working
I am unable to allign the touch screen properly what do i do, i have tried to allign the screen correctly on the settings menu > Screen but this has not helped...i need help. Thank you Bharath
Touchscreen not working when I touch it
Have you tried to reallign the screen? You can navigate to it by pressing your Windows Hard Key, scroll to settings, then over to system, then screen. This all can be done
Sep 05, 2013 | Samsung SGH-A877 Impression Cell Phone
Samsung SGH A897 mobile touch screen not responding to touch Incoming calls are operable
Did you try restarting the phone...??? If it didn't work try resetting everything. And even if that is not working then I would say it's probably a hardware error. You would have replace your touch panel. Could cost you a little bit. Rush to nearest samsung service center and get it done.
And also bear to put a screen gaurd always. I would not advise you to use touchscreen phones without screen gaurds.
Good luck
Jun 23, 2011 | Cell Phones
My samsung sgh t929's touch screen does not work, plz help me
Mobile touch screen problems solution :
1- First: Reinstall the mobile FIRMWARE ,most of mobiles touch screen problems solved by
reinstall the mobile FIRMWARE.
2-If the reinstallation of the mobile FIRMWARE didnt solve the problem that means the touchscreen
needs to be changed.
Jun 18, 2011 | Samsung Memoir SGH-T929 Cell Phone
My Touchscreen is not working, do you have an idea ?
remove ur touch screen safe guard sticker then clean display. If that fails you will need to contact the shop you brought the phone from.
Any further questions feel free to ask.
Correct? vote would be awesome.
Nov 19, 2010 | Samsung SGH-D980 Cell Phone
The touchscreen on my Samsung Impression SGH-A877 does not work at all. Started about a week ago when I noticed that it was not selecting the things I touched on the screen, but selecting the entry above...
Hi,you will have to replace the flex of the phone.
The flex make the touch pad to function,also the functioning of the number keys.
When you replace the flex the touch pad and the key will function again.
Thanks for using fixya.
Oct 01, 2010 | Samsung SGH-A877 Impression Cell Phone
Unable to touch the correct menu and when dialing it goes to another number
try to celebrate touch screen if not helping its time to change the touch screen
Aug 24, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
Hello, I've got Samsung SGH-D980. My touchscreen is working but when you touch it activates the button that is aprox. 1cm. higher then the touched place. Probably there is some calibration problem, but...
Hi,the reason why the touch screen is not functioning ,is because the touch screen is dead does not work properly again.
You will need t replace the touch screen for it to function properly again.
Have a nice day.
Aug 06, 2010 | Samsung SGH-D980 Cell Phone
Touch screen does not work on my samsung impression
The mobile screen would have been damaged or a device connected to your screen my be defected .Try to remove your touch screen safeguard sticker then clean the display. If this doesn'twork out for you consult your dealer for replacement of new display.
Thank you !!
Jul 24, 2010 | Samsung SGH-A877 Impression Cell Phone
I have a Memoir SGH-T929 and the touchscreen is not working properly. I push the call log and it takes me to the phonebook and won't let me call anyone, but whoever is the last person to call me I can call...
You have to go to MENU->SETTINGS->PHONE SETTINGS->
touch CALIBRATION and press OK when the new settings save.. that should solve the problem. Your phone just needs to be aligned. Good luck
www.usedcellphoneshop.com
Jul 14, 2010 | Samsung Memoir SGH-T929 Cell Phone
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
185 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
