I'm having trouble with my dchp server in my Netgear FSV114. Its giving out the ips that I want but when I ping from one computer to another it says request timed out HELP Please
  • 30 Answers
Firstly, don't think that PING is 100% reliable, it is a very useful tool, but the packets can be failing for a number of reasons, and can be filtered or dropped because a device is too busy, or a number of other reasons.
However, if the test works fine from your laptop, but not through the router, then the router config is a very likely candidate as the cause of the problem.
Have you tried the PING test from the router itself ? Did this also drop the packets ?
If that works, then it is the router config that is probably at fault, if that also fails, then it may be a routing issue, or a problem between the router and the modem. If that is Ethernet, have you fixed the speed and duplex ? Try setting it to auto, reset the link, and try again.
Posted on Sep 07, 2009
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
I have installed a antamedia dhcp server, but it does not give out ip addresses. please guide me on how to set this up. i have awindows machine connected to a linksys router 10.0.0.1 and the computer int...
Make sure DHCP is off on the Linksys router first, set the IP of the router inside the scope of your DHCP server's scope (set it as the gateway so if your using 192.168.1.X, set it to 192.168.1.1). After that, remove static IP settings on your desktop (except the one using DCHP, set that to 192.168.1.10)
Mar 01, 2011 | Antamedia DHCP Server
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
Jan 30, 2011 | Zonet ZPS2102 Print Server
We have a DHCP problem with our thin client HP T5540, the network interface can't get an ip address fom the DHCP server for 30 seconds so it can't connect to citrix xen serverver for virtualization...
First of all check the configuration of the unit if it's AUTOMATIC IP/DHCP, if all OK you can test by configuring a static IP (use an unused IP in the server's DHCP table) than check the connectivity (ping something), if that works you have a server rule/DHCP or DNS problem
if it's still not working check the cabeling and connectors for connectivity (with a good cable tester) or an other (working) computer.
Oct 22, 2010 | HP t5540 VIA Eden 1GHz Thin Client...
My computer shows connected but I can't get online I have a wireless netgear card in the laptop and a linksys router. I can see the network, and the computer shows connected with the icon at the bottom and...
check that u have properly configured ip address
gateways and dns
try pinging gateway if u get ping then try pinging ur dns servers.
if u get ping from dns server ur brouser might got curropt if not you need to reconfigure ur wireless router.
Feb 06, 2010 | NetGear (IM-WG511T) Wireless Adapter
I have a netgear wgps606 wireless print server. I
Manual Configuration of WGPS606 Print Server
Note: Before configuring the printer server please check if you printer is compatible. You may open this link to you web browser: http://kbserver.netgear.com/kb_web_files/N101216.asp.
1. Please make sure that the printer works when connected directly to the computer.
2. Confirm the wireless settings of your router. You should have the SSID, wireless security and IP address of the router.
For NETGEAR routers please follow these instructions to check the wireless settings:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab and you may get the wireless settings on that page.
e. On the left side under Advance setup, click on the LAN IP setup and locate the LAN TCP/IP Setup. Underneath that is the IP address of the router.
Note: If your IP address is 192.168.1.1, then you may use 192.168.1.200 for your print server.
3. Please connect a computer to the print server. At this time, the router is not connected. The printer should be connected to USB1. The power, LAN port and LPT1 should be lit.
4. Assign static IP address to the computer.
a. Click on Start and right click on Control Panel.
b. When the Control Panel window opens, double click Network Connections.
c. Right click on Local Area Connection, then click Properties. When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then hit Properties button.
d. Change the option from Obtain an IP address automatically to Use the Following IP Address and enter the following:
IP: 192.168.0.50
Subnet Mask: 255.255.255.0
Note: Leave the default gateway and DNS addresses blank.
f. Click on OK and then Close. Exit out of all the Windows.
5. Ping the print server.
a. Click on Start and then Run. Type cmd and hit OK.
b. On the DOS prompt, type ping 192.168.0.102. This should give four responses.
c. If it gives request timed out or destination net unreachable, please turn off both print server and computer. Wait for few minutes, then turn it on again. You can also try holding the reset of the device. Then repeat steb 5.b.
6. If you are able to get replies, you may now open Internet Explorer and type 192.168.0.102 on the address field.
7. After hitting go or enter on the address field, it will ask for a login. (Please type in admin for Username and password for Password).
8. Click on Wireless Settings under Setup tab and we need to set the same SSID as your router.
9. Please also select the appropriate Wireless Security and type the network key or wireless password from the router. Then click on Apply to save the settings.
10. When you get back to the page, click Print Server settings.
11. Check Change to and set the following:
IP address: 192.168.1.200 (It should be on the same range as the router. e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). This will be the print server's IP address.
IP mask: 255.255.255.0
12. Click Apply to save the settings. We will get a Page cannot be displayed.
13. Set the IP address of the computer back to dynamic.
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then click on OK.
For Windows 98 and ME:
a. Please click on Start, then Settings, and then Control Panel.
b. Double-click Network then select TCP/IP for the Ethernet adapter. Then click on Properties.
c. Go to IP address tab and select Obtain an IP address automatically.
d. Click on the Gateway tab and delete the numbers under the Installed Gateway.
e. Click the DNS Configuration tab, and then select Disable.
f. Click on OK. Windows will then prompt for a restart.
14. To set up a TCP/IP port to the computer, please follow these steps:
b. Double click on Printers and Faxes.
c. Right click the printer icon and go to Properties.
d. Click Port Tab and click Add Port.
e. Select Standard TCP/IP port. Hit OK or Next.
f. In the field for Printer Name or IP Address: enter the IP address of the Print Server and click on Next.
g. Select Custom and then click Settings.
h. Under Protocol select LPR, and for Queue Name, type L1 if printer is connected to the print server USB port 1 and L2 if the printer is connected to the 2nd port.
i. Click on OK, then Next, and Finish.
j. Lastly, please right click on your printer icon and select Use Printer Online. If this is not an option, disregard it.
15. Check if you can print through the print server.
16. If it is not printing, then please try to connect the print server to the router and check if you can print. If it can, then there might be a need to re-do the steps for wireless configuration of the printer server.
Mar 29, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Netgear Print server
IP: 192.168.0.50
Dec 18, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
No longer pinging...
check the cables, it's possible that a wire used for the comm. from the server to the switch/router is not making proper contact or is broke...
Jun 24, 2008 | NetGear 24-Port (fsm726s&mr814) Networking...
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping yahoo.com and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Cannot set up
Have you run a configuration test page to find out if it really has an IP or not? If yes, have you "pinged" it? (at the command prompt type ping then a space then the IP address of the printer) see if it gets a reply.You should be able to get to the print server page (with the browser; type \\prtserver's IP in the web browser) if the unit is good.
Aug 29, 2007 | ViewSonic WPS-100 Print Server
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
