Water leaking from under the tub from bottom side looking at it with the front panel removed , looks like when it agates it leaks out of a couple slits in shaft were it conects. bad seal? model A490 washer
    President:
  • 1,564 Answers
Yes, and a very difficult job to acheive without an agitator removal puller. You've got to have some serious mechanical capabilities to perform the seal exchange. Best choice, a new machine, because by the time that seal wears out all other components cannot be far behind. Sorry, Good luck my friend, Dana
Posted on Sep 06, 2009
When filling machine it leaks water
Are you talking about a washing machine? If so, you can remove the front panel of the washer by placing a scraper blade under the top panel to push in the metal clip that holds it on. Then look to see where it's leaking. Is it leaking from a hose (easy fix) or the bottom (hard to fix). The bottom has a gasket that can fail and requires removing the tub. Some u tube videos show how.
Feb 15, 2016 | Washing Machines
It is leaking on the bottom when I do laundry. The hoses are fine. The water seems to be around the edges on the bottom of the washing machine. The machine is only 5 1/2 years old.
if you look at the front inside panel and the side panels nd if you see like black spots half way up the panel you have bad tub seals and that's what it sounds like you have.the tubs have to be separated and the middle seal has to be changed out.you need special tools to do this job.might be better replacing the washer if it's the problem.fill it with water,run it and look at the tranny part coming out the middle of the tub on the bottom of the tub,let it agitate and put it in spin,if you see water leaking out the middle of the tub it's the tub seal
Jan 19, 2011 | Amana Washing Machines
My he3t washer when water goes in tub it leaks
most liklet to be a split pipe under the mashine lay it onits side and look under it at all the pipes replace the loos or split one
Oct 25, 2009 | Kenmore HE3T Washer
Leaking water out bottom of front load washer
You will need to remove the lower toe panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Check the air dome on the lower right hand side of the wash tub. There should be a small air hose attached that runs all the way to the pressure switch. This small air hose is how the pressure switch senses the pressure differential in the wash tub and determines when to shut the water off. If the air hose comes loose, water will pour out of the air dome into the cabinet bottom. Reattach if necessary.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: You can refer to searspartsdirect.com for some excellent exploded view diagrams of your washer for reference in locating components. If y
Oct 23, 2009 | Kenmore HE2 Plus Front Load Washer
Water is leaking underneath and pouring out of side
If this is a Whirpool Duet front loader, you will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link epxlains how:
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool is leaking from the bottom during
The only way to determine where the leak is coming from is to remove the lower kick panel directly below the door. Remove the panel by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then off. If you prop the front feet up this will give you better access (a 2 x 4 works well).
With the panel removed inspect the rubber door bellow. If the front counterweight (gray concrete block on the front of the tub) is wet, the bellow is leaking. Pull the rubber folds back and look for any rips or tears. If the bellow requires replacing, or if you need to simply tighten the clamps, the following link will explain how:
NOTE: Check the plastic dispenser hose on the left hand side of the bellow to ensure it is inserted all the way through the rubber to the flange joint. Sometimes this dispenser hose will slip behind the bellow and allow water to seep inside the cabinet of the washer.
Check the drain pump to ensure the filter cap is secure and not leaking. The pump is in the front directly below the wash tub. If the pump IS leaking, make sure the filter cap is tight and all hose clamps are snug. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Check all hoses the run from the wash tub to the pump, and from the pump to the standpipe at the wall for any signs of cracks or tears.
If the leak is coming from the center portion under the tub, the tub seal is breached and needs to be replaced. This is not an easy repair and will require some extensive disassembly to repair. (Cross that hurdle when the time comes).
Any replacement parts you may need can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. You can use any web source you like, but these I have found, offer great service with competitive pricing. Shop all of them for the best prices. Hopefully you won't need any parts.
If you have any questions, please let me know. I hope this helps you.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Washing Machine leaking water
Okay...my experience with this model front loader leads to the following possible problems:
CAUTION: UNPLUG the washer if you plan to service the interior. It is dangerous to have your hands inside the unit with moving parts and energized. Plug the washer back in and stand back if you plan on doing any operation checks.
1. Door bellow ripped or torn (this is the gray rubber boot around the door - open the door and inspect along the entire door boot. Including the areas behind the rubber fold where the rubber meets the wash tub. It is common for them wear out and tear. NOTE: Make sure the fill hose on the left-hand side of the door boot is fully snug in place. Sometimes it will come loose and leak BEHIND the door boot.
2. Drain pump or hoses leaking - You will need to remove the lower panel under the door to see inside the washer. Remove the three torx type screws under the front lip at the bottom of the panel. For easier access, place a small block of wood under each front foot. The washer is heavy so you may need assistance to lift the front slightly. CAUTION: Do not lift on the door, push on the door panel or control panel. If the panel sticks, slightly tap on the sides and it will drop down and come off. The pump is located in the front under the wash tub. Make sure the clean out trap is snug and all your hoses are tight and not torn. Check the drain hose that leads out of the back of the washer from the drain pump to ensure it is not cracked.
3. Air Dome hose has come loose from the tub - This will be a small rubber hose connected to a plastic piece (called an air dome) on the right-hand side of the wash tub as you are looking in from where you removed the bottom panel. It should be located behind the drain pump and mounted physically to the wash tub. The other end of this hose runs to the pressure switch, which turns the water flow off when the washer tub fills to the approriate level. If this hose comes off, the washer will start to leak on the FILL cycle and will not shut off. I don't think this is what you are talking about, but it is still worth a look since you have the panel opened.
4. Tub seal leaking or tub cracked - These would be the most undesirable of all possible problems because it would require the removal of the entire wash tub in order to correct. Inspect the wash tub seam and make sure there's no water coming from around the tub.
I hope this gives you a few possible items to work with. Inpsect the washer interior when you get the panel off and post back if you can determine where the leak is coming from.
HELPFUL HINT: Put the washer into diagnostics mode if you plan to leak test. At the control panel select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, however). "C00" will be displayed on the operator console, and you will hear the door latch engage. The washer will run through a series of tests by filling using hot and cold water, checks all your dispenser features, tumbles the drum, spins and drains. This diagnostics can be stopped at any time by pressing the PAUSE/CANCEL button twice. The drain pump will come on and drain the washer.
I hope this helps you...
Feb 20, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
