Question about Kitchen Ranges
What does a F-3 fault mean when using the oven
When we use the oven, a F-3 alarm keeps coming up repeatedly even after being cleared. The range is a 15 year old glass top Magic Chef model number 3868XVA
  • 220 Answers
That is a bad sensor code you can ohm the sensor if you have an ohm meter it should be 1050 to 1110 if tested at room temp,You'll find the sensor in the upper left corner of the oven looks like chrome rod coming from the wall.
Posted on Sep 06, 2009
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
The F1 alarm is beeping.....what does this mean? Thank you!
The "F1" fault code implies a faulty oven temperature sensor. In order to diagnose which will require disconnecting the oven temperature sensor from inside the oven cavity and measuring the resistance using an ohm meter. The oven temperature sensor probe should measure approximately 1100 ohms at room temperature.
Here is the temp. sensor to order.
Dec 01, 2012 | Magic Chef CEL1115 Electric Kitchen Range
I'm not even using my oven and the F2 alarm keeps sounding every minutes. What is wrong?
First, check the oven sensor and see if it reads 1080 ohms @ 77 degrees F or close to that at room temp. Post back your results.
Nov 18, 2012 | Hotpoint RGB745 Gas Kitchen Range
F1 fault when oven is just sitting.
There are several sufix numbers after your model number so I just picked one, They are often the same as they usually keep the same wiring harness and circuitry through out many.Here's what I've found, Electronic control has detected a fault
condition. Press CLEAR/OFF to clear the display and stop the
beeping. Reprogram oven. If fault remains, record fault number.
Press CLEAR/OFF and contact a Service Professional. See:
https://www.searspartsdirect.com/partsdirect/user-manuals/GLEF396ABA-Frigidaire-Parts-Range-Parts-manual#
or choose from your complete model number:
https://www.searspartsdirect.com/model/search.html?q=GLEF396
Good luck
Oct 30, 2017 | Frigidaire GLEF396 Electric Kitchen Range
What does the F3-1 code on a Maytag flat top double oven range mean?
Well error F3 means open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. The error F3-1 indicates problem with Sensor of upper oven
Solution - Check sensor and wiring for shorted or open circuit. you need a multimeter to check them. Please post comments for further help or information........
Good Luck!!
Thanks for using FixYa!!
Dec 18, 2009 | Maytag Kitchen Ranges
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Alarm fault code
f-2 is a faulty temp sensor. replace the oven temp sensor to solve problem
Nov 19, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
