Question about JVC GR-D370 Mini DV Digital Camcorder
Will not work
Have a miniDV Cyber Cam. Code EO4 shows up on the screen
  • 489 Answers
Solution #1: Cold Reset
The reason it tells you to REMOVE AND REATTACH BATTERY is not that the
battery is bad, but that removing all sources of energy (battery and power
cord) causes a COLD RESET. When you use the unit's on/off switch, parts of
the camera are still receiving power and so you do not get the benefits of a
COLD RESET. Just like your car; turning the ignition off will still power
the clock and radio. You have to completely remove all power. If you are
lucky, the camera will reset itself and start working again.
Solution #2: Awareness of Humidity
It seems older units would issue the same SAFEGUARD MODE error message for
more than one problem. For example, older units do not tell you that they
are shutting down for an hour because they detected high condensation, or
moisture. So you play with the camera, remove the battery, reattach it,
remove the tape, reinsert it, stand on your head, pray to your god, go to
the bathroom, and voila! The camera is working again. It was nothing you
did, just that the humidity went down enough for the unit to start working
again. So consider high humidity as a possible source of the problem. If it
is a rainy day, or you are near the sea, you might never get it to work that
day in that location.
Solution #3: Head Cleaning
If you have never used a head-cleaning tape on your camcorder, you might
give that a try. Mine has come back to life a few times by doing just that.
Just don't do it too many times in a row because you can permanently damage
the head. Read the instructions.
So we have covered a few reasons why these errors come and go as if by
magic. They are intermittent and recurring. The camera will appear to work
at times, and the next minute it shuts down.
Solution #4 : Fake Solutions
Another reason why the problems come and go is that, as several technicians
have reported, the problem can be a loose connector inside. That is why some
people report that tapping the camera gently or rocking it side to side has
brought it back to life. Some have gone as far as putting cardboard between
the tape door and the tape mechanism in order to exert pressure and keep the
camera working. I can only warn you that these kinds of "repairs" are
temporary and likely to damage the unit further. Control your anger!
Solution #5: Compressed Air
On some models, there is no shield covering the many delicate electronic and
moving parts in the tape mechanism when you open it to replace the tape. A
piece of dirt, grain of sand, or other debris can get caught in the tiny
gears and stop movement or throw them off alignment. You can explore this
possibility by getting a can of compressed air at any computer shop and
blowing it into the inside of the camera. Follow the instructions, keeping
the air nozzle however many inches away from the target as they say.
Practice on some other object first, because if you tilt the can or hold it
too close to the target you can freeze the target and do more damage than
good. This applies to fingers too!
Solution #6: Tape Age, Brand, and Type
Have you tried using a brand new tape? Or only your really old ones? Try a
new tape.
Now for the controversial issue of what brand of tape to use. Controversial
because JVC's own Stacy Sample, Service Coordinator for JVC in Houston, TX
says that "TDK and Maxell tapes tend to be two brands that are very
problematic in our digital line wherein Panasonic, JVC and Fuji seem fine.
We just find that TDK has the most problems, Maxell is a close second and
Sony is 50% of the time. The others I mention rarely have a problem." Why
JVC does not make this information available when you purchase the unit or
visit their many websites is beyond me.
A different point of view I ran into is. Yes, there is an issue, but it has
nothing to do with the brand, but with the tape type. There are MP and ME
tapes. These two types use different particles, and different lubrication.
The two lubricating materials form some sort of goo when mixed together, if
you use both types of tape in the same unit. So as long as you don't mix
tapes of different types, they will work just fine in your camcorder. Some
refer to these types as "dry" and "wet", but I don't know which is which. In
any case, it is not known (to me) how accurate this point of view of not
mixing tape types is.
Solution #7: Do not store tape in unit
Because of the delicate nature of the miniDV mechanism, do not store the
unit with a tape inside. The theory is that a loaded tape will put pressure
on parts of the mechanism and increase the chance that parts will stick
together, making the tape harder to be pulled by the motor, causing the
SAFEGUARD error.
Posted on Sep 06, 2009
What does code eo4 mean?
Depends on make and model possibly year. I just googled
"code eo4" and lots of different appliances use that code. So I recommend you add what it is and the code, you may get an answer and a solution.
Mar 11, 2015 | Heating & Cooling
Hoover code eo4
Call the service for this product.
Feb 01, 2014 | Washing Machines
How do I clear error code eo4 on my casio ce 3700
What were you doing or trying to do when you got this error code?
Apr 09, 2012 | Computers & Internet
What is a eo4
ERROR CODE EO4 SAYS TAKE TAPE OUT AND REINSERT IT BUT TAPE WONT COME
Sep 10, 2009 | JVC GR-D73E Mini DV Digital Camcorder
Sony DCR PC9E - Handy Cam - Nothing is functioning: Here What I did. I was trying to eject the MiniDV, the ejected miniDV struck in between while ejecting, then I presssed the reset button of the camera,...
hold reset with batt on cam. then place on wall charger. back and forth till it ejects tape fully. if this doesnt work flat rate to send in usually is about 250
May 31, 2009 | Sony Handycam DCR-PC9E Mini DV Digital...
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
USB Not working =S
Possibly, the cam is in webcam mode or other mode beside camera mode. I have an older sony and there is a mode that doesnt seem to work for me too. Im not next to it so I cant tell you what it is, but look into the setup screen and make sure the camera is in USB mode.
Mar 04, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Samsung Mini DV VP-D303D digital-cam
I need the CD for my computer but i don't know where to get it?
Troubled
Jan 06, 2008 | Samsung Compact MiniDV Digital Camcorder
Sony cam recorder - wont record
Haggai, There's a problem on the CCD Imager Processor,it is located inside, exactly behind the lens,if you're not qualified tech.not try to open it,bring it to SSC (sony service center) Fred Loja
Jan 26, 2007 | Sony DCR-HC30E MiniDV Camcorder
JVC GR-D370 Mini DV Digital Camcorder Logo
219 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
