Question about Hitachi 57SWX20B 57" Rear Projection Television
Hitachi 57SWX20B 57 in. Rear
The picture will sometime fluctuate in varying colors (fading in and out) and even black and white.
  • kotkot Dec 14, 2007
    Don't know. Will have to search what a convergance amp ic is???
    Thanks
    President:
  • 4,402 Answers
Convergance amp ic going?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
  • Cary Farah
    Cary Farah Dec 14, 2007
    convergance amp brings all three of the colored tubes together.
The color on my Advent TV fades in and out of the picture, and goes to black and white Why
The problem is in the picture tube board circuit. Sometimes the CRT socket doesnt connect well to the CRT pins. Or maybe there have bad solders from RGB transistors. check those transistors, Also the bad thermistor discolored the entire tv screen.
Sep 29, 2014 | Televison & Video
Faded prints samsung clx3185 fw
Got one clx 3185fn printing black only. even press color copy button.
Cartridges are new. Please advise.
Thanks
mearmi@hotmail.com
Oct 26, 2012 | Samsung CLX3185 AllInOne Laser Printer
Green and blue faded
Some of these had bad picture tubes--(model indicated here uses 3 tubes)
Simple test is go to a black and white channel and turn color to zero= is the screen black and white or some other color?
Also go to a unused video input and look at screen=all you should see is black screen with the input number in green= any other color and something may just need to be adjusted.
Apr 15, 2012 | Sony KP-65WV700 65" Rear Projection HDTV
Color is terible and can fix it
This DLP tv have a colors wheel.Ur tv colors wheel is dead.When u have black & white picture,colors fade in and out.The tv make loud squiling or loud motor noises.All these problems are related to the colors wheel.Hire a tv repair Tech. for this job,because the colors wheel,require take out alots of machanical's parts out even before to get to the colors wheel to replaced it.
May 29, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Color is horrible basically black and white
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
May 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
Razr inner screen fading, flickering
take the phone and have the LCD replaced on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
Color fading to black and red "nightvision" picture
We have a 60" panasonic rear projection television and the color fades in and out. What do you think is the problem the tv is only two years old and is now starting to apear in black and white sometimes. What can be the problem?
Oct 03, 2007 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Color Fluctuation
You could have either some bad solder connections or capacitors going bad in the chroma or voltage regulator circuits. As long as the picture is great when it's working, it should be worthwhile repairing.
Jan 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Color fades in and out of picture
The first thing I would check is the antenna or cable connection into the set. When an analog TV signal is weak, the first thing to go is the color, then the picture, then the sound. If you have another TV, connect it to the very same cable or antenna connection and see if it fails the same way, too. Make sure you just disconnect the cable end right where it goes into the failing TV and connect it to the other TV - don't disconnect the antenna cable from the wall for this check. If the second set does not fail, gently pull on the antenna wire - not too hard, you just want to put a little tension on it to see if it makes the color cut out. Reconnect the first one and try again. If it's fine now, the connection was loose. If not, it has a tuner problem that must be repaired. Also, when you look at the end of a TV connector, the center wire should stick out just a little bit, like in the attached photo. If it doesn't stick out as bit, it won't make good contact, and will result in a weak signal. I appreciate your rating if you find this helpful.
Nov 13, 2006 | Philips 27PT643R 27" TV
Hitachi 57SWX20B 57" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
