Labtec Personal Web Camera
Problem for Labtec (961307-0914) Personal Web Camera
My cam always says server busy pls try again later
By vicky_vickie on Sep 06, 2009
My A4 tech cam always says "server busy, pls try again later" i tried every suggested solutions from other sites but they simply won't work.
Solution #1
posted on Sep 26, 2009
Not Rated)
yooperbud
Rank: Wiz  Computer Accessories  Expert
Rating: 82%, 2193 votes
This program will eliminate your problem of the camera being busy or being used by another program. Really works great.
Copy this site and paste it in your web browser address bar and hit ENTER.
http://download.cnet.com/SplitCam/3000-2348_4-10500269.html
And then click on Download Now (3.5MB)
1. Install Splitcam saying yes to everything during installation including the any warnings.
2. Then run the Splitcam program by double clicking the downloaded program.
3. Clicked on "Video" at the bottom right of the program window and selected your cmera.
Note: This will result in your camera being switched on and viewable in the
SplitCam program.
4. Opened up Skype (or other messengers) and go to "Tools" then "Options" then "Video settings."
5. Also setup your “Audio” while you are there.
6. Selected "SplitCam Capture" as my webcam, then click on save.
7. Webcam image will appeared in Skype or what ever messenger you are using.
Hope this Helps. Bud
Comments:
Nov 18, 2009
- Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and
Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html )
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the
4. Next go to the Test Audio section and (in blue writing) click on “Open the call
setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on
top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.”
And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or
friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and
video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window.
If you are currently participating in an AOL Live Video IM session, a message will display:
You must disconnect the current AOL Live Video IM conversation before running setup. Would you
like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers
and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to
first check your audio and video settings? Click the Yes button. The Audio and Video Tuning
Wizard will appear to help you verify that your camera, speakers and microphone are working
· Images in AOL Live Video IM may appear reversed, or as a mirror image (text may
appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will
cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Hope this helps. Bud
Was this helpful?
Yes
No
Popular Solutions for Labtec Personal Web Camera
Questions and Unsolved Problems for Labtec Personal Web Camera
Do you recommend Labtec (961307-0914) Personal Web Camera?
Answer
Answer
When ever I try to connect my web cam to yahoo messenger it responds Server busy. Try again later. I... (More)
Answer
i d not have my friends password when i downloaded messengr, and now i cant find the set up page... (More)
Answer
My webcam appears to be working fine on messenger but only lasts about a min and then cuts off, plus... (More)
Describe your Web Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Web Camera Experts
Top Computer & Laptop Repairmen
in , GA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
