Question about Singer 7422
Singer 7422 beeps and all lights come on when peddle is pressed.
My wife was sewing on her Singer 7422 last night, and it stopped while working. All the lights on the panel came on, and it made a constant beeping sound. After turning it off and on again it makes the same beep and the lights come on when you press the peddle. I have tried the buttonhole lever and the needle position, neither seem to make any difference.
  • 136 Answers
There are several sensors on this machine that just start causing the machine to malfunction for no apparent reason. One is one the bobbin winder, one on the buttonholer, and one under the machine which workd with the feed. It is far from an exact thing. If you can get to them, sometimes loosening them, moving them about then tightening them seems to 'fix' them. Sometimes not. Wish we could be more exact in explaination but sometimes we will move them repeatedly then they start working. It is hit and miss.
Posted on Sep 08, 2009
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
www.fixya.com/support/t26006759-singer_7422_keeps_stopping_lights
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Dec 13, 2015 | Singer Sewing Machine 7422
How do I stop all the lights from linking on model 7422 singer sewing machine
I'm assuming that your machine doesn't work--it just blinks the lights. It indicates that something is stopping the machine from setting itself up to sew. Most likely, it will need to be serviced, but you CAN at least rule out user error. Download the user's manual, and starting from scratch, make sure you have properly threaded and set up your machine. They also may have additional suggestions regarding the machine's behavior. There is often a troubleshooting part at the back of the manual. You can download it free at the Singer site.
Oct 30, 2014 | Singer Sewing Machine 7422
Why won't my bobbin winder work
It could be the belt has snapped, or something else it out of adjustment. You can either get it fixed, or purchased an inexpensive bobbin winder for under $25 from WalMart online.
Oct 18, 2014 | Singer Advance 7422 Electronic Sewing...
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
Start sewing and starts beep say e2
try rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
May 20, 2012 | Singer 7422
Singer advance 7422 beeps when i am trying to sew
are you getting a visual signal on your LED display ?
have you tried turning the machine off & waiting a few seconds & turning it back on again
have you tried cleaning the bobbin area for loose threads & lint?
how many beeps are there?
do you have a instruction manual for the machine? if not singer has one for free pdf download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 7422 ) & click search
Feb 01, 2012 | Singer 7422
My machine beeps and will not sew when the foot peddle is pushed. i checked the BH lever inside the light cover and the small black switch appears to be in the up position. any other ideas?
make sure the foot pedal cord is pushed in correctly
rethread the machine top & bobbin
clean under the needle plate where the feed dogs are for lint
also clean the bobbin are for lint or loose threads
change needles
but also the foot pedal could have gone out
Nov 19, 2010 | Singer 7422
Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Oct 31, 2008 | Singer 7422
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Singer 7422 Logo
679 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
