Question about Euro-Pro EP601 Bagless Upright Cyclonic Vacuum
Brush roller has stopped turning - Euro-Pro EP601 Bagless Upright Cyclonic Vacuum
  • 430 Answers
Look on the bottom of the unit for a small reset switch button.I have not worked on this unit but many are similar. If you can hear the roller motor running you may need to replace the belt
Posted on Sep 07, 2009
Dyson animal ball, brush stops rotating often. Restart vacuum, brush head runs very short time, shuts off on flat tile floor.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 12, 2017 | Dyson Vacuums
I have a Dyson wand vacuum and the beaters have stopped turning
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Apr 23, 2017 | Dyson Vacuums
The brush of my shark cordless vacuum keeps stopping
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
Ava B.
Apr 14, 2017 | Shark Vacuums
Dyson DC27- machine stays on with red button but beater brush won't stay on while vacumming low carpet.
Ava B.
Feb 10, 2017 | Dyson DC27 Bagless Upright Vacuum
Why the Dyson dc 41 roller brush will not turn?
Try these steps:
  • Check the button that turns off the roller brush to make sure you didn't press it by accident.
  • Unplug the vacuum and clear pet hair and other debris off the roller brush. It may stop as a safety feature if the roller brush is too restricted.
  • Make sure the belt to the roller brush is placed correctly and not broken.
  • Press the roller brush reset button. It may be located on the side of the vacuum's head, or inside the handle. The switch may need to be replaced if it's defective.
  • The roller brush is disabled while the handle is in the upright position, so tilt the handle backwards while testing the roller brush.
I hope that helps you!
Jun 21, 2014 | Dyson Dc 41 Ball
Dyson dc44 brushbar
https://www.thinkcrucial.com/search?type=product&q=dc44
Ava B.
Jun 17, 2014 | Dyson DC44 Animal Cordless Vacuum
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
Turbo brush on bissell cleanview helix stopped spinning
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Feb 07, 2012 | Bissell Cleanview Helix Deluxe Bagless...
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Euro-Pro EP601 Bagless Upright Cyclonic Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
