Question about Kenmore 22422 Top Load Washer
Washer 22632 sits and clicks continuously after draining
It can't seem to start to spin as spin dry would. It just clicks and clicks as if it's fighting itself.
    President:
  • 1,564 Answers
You'll need to unplug the washer and then remove the hook end of the drain hose from the drain itself. Lower the hose to a bucket until it starts pouring water and empty the drum in this way. Next turn off and disconnect the water supply lines. Put a piece of carpet or a doormat on the floor and lay the washer on it's side.You'll still have a small reserve of water to contend with using a mop but it won't be overwellming.Check the drivebelt for signs of wear and or breakage. Turn the large pulley in the center of the machine clockwise and counterclockwise several turns in each direction. The motor reverses itself to pump and spin and again to agitate. If these turns prove to be difficult in either direction, you'll probably need a new transmission or a new machine, depending on your mechanical expertise.P.S. remove all clothes to perform the previously described test.Good luck, Dana
Posted on Sep 06, 2009
Testimonial: "they are very difficult one direction, thanks very much!"
Maytag lsg7806aae tub does not drain before spin cycle starts
Drain pump getting clogged or jammed I would start there.
Apr 19, 2013 | Maytag Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
WASHER FILLS AND AGITATES, BUT THEN STOPS, WILL NOT DRAIN OR SPIN
It may be a bad lid switch. Cheak with your meter for continuity.And if you need more info let me know.Also how old is the washer for there are 2 differant styles of lid switch dipending on how old the washer is. hope i helped :)
May 18, 2009 | Roper RAX4233PQ Top Load Washer
Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
May 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
