Question about Kenmore Sewing Machines
The needle wont move up or down - Kenmore Sewing Machines
    Problem Solver:
  • 5 Answers
Bobbin winder is on or bobbin lock engage
Posted on Sep 06, 2009
Lervia sewng machine. material wont feed through. Dogs are up but material just wont move through. needle moving freely.
Hm, could be several things. If stitches are not being formed, it could be a timing issue (the needle does not arrive at the bobbin at the correct time). Did the machine recently hit a pin or something hard? That will knock a machine out of time. There could also be a broken piece stuck that is preventing the feed dogs from operating. Thoroughly clean the machine around the bobbin area and feed dogs.
Jul 28, 2016 | Sewing Machines
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
Auto threader wont thread
Move the needle to the top.
Loosen the screw on the threader.
Use the threader as if you are using it. You will have to adjust it to the side and up or down. Move it so the threader is in the needle hole.
Tighten the needle.
If it still doesn't work you may need to replace the threader.
Apr 18, 2015 | Sewing Machines
Needle wont move singer 478
I have a Kenmore sewing machine. I'ts about 30 to 40 years old. I have never had a problem with it until today. The needle got stuck down where bobbin is. I don't know if it should be seen by a pro. I can not get the needle out. The Bar on the side will not move either way. help...........!
Jul 06, 2013 | Singer Sewing Machines
The needle on my model 1315 Kenmore sewing machine wont go up and down.
try turning the bobbin in the opposite direction & see if that helps
Jul 30, 2012 | Kenmore Sewing Machines
Arm wont move and needle wont go up and down any more in the middle of sewing, I was in the middle of sewing and all the sudden it froze up. It wont move any more and when you try you cant hardle move the...
Annoying solution, but works every time. Remove the ENTIRE bobbin casing from the base and then turn the wheel. The needle should lift right out. Reassemble bobbin casing and oil very well.
This generally only happens when you are sewing through several layers of fabric or though a thick fabric. If you are doing neither, the timing in your machine may be off and you will need to get it repaired.
Jul 04, 2010 | Singer 3116 Simple
Needle wont move up and down.
Check the settings for bobbin winding to be sure they are not activated.
May 08, 2010 | Brother LS-2125 Mechanical Sewing Machine
The needle wont move at all?
Hello we had the same problem with our sewing machine. After playing with it we found there is a bobbin winding assembly lever that moves back and forth. By moving it the needle moved. This helped us. Hope it helps you. embreyR97@yahoo.com if you have questions.
Jan 05, 2009 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
44 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
