Question about Dell 430-0008 Network Adapter
I have limited connectivity. Both my Broadcom 440x 10/100 Integrated Controller and Dell Wireless 1390 WLAN Mini-Card drivers are up to date.
    Sergeant:
  • 324 Answers
Make sure the access point or router is on DHCP then connect the computer, but if its on dynamic IP... them enter an IP in range of what you have on your AP/Router
Posted on Sep 08, 2009
Hi. You can download the driver from Dell website. I strongly recommend that even there will be more recent versions out there, stay with the versions released by Dell, Dell before releasing a driver tests it with the systems to ensure full compatibility and zero-problems with other devices:
Dell Wireless 1390 WLAN mini-card driver
Also for future needs, it's advisable that you go to the following web page:
Dell Drivers & Downloads
And enter the service tag of your Dell computer, so that you could get drivers specific to your system.
hope it helps
Oct 22, 2012 | Microsoft Windows XP Home Edition
Can't make a wireless connection.
what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
Jun 03, 2010 | Intel Computers & Internet
Cannot get Internet connection with Broadcom 440x controller.
are you sure the connection in "my network places" is for that adaptor? try going to system properties - hardware - deivice manager and check the network card is properly installed there. you may need to update the drivers which u will obvioucly have to download from another computer.
Jul 02, 2009 | Broadcom Computers & Internet
Browsers on Dell Inspiron E1505 won't bring up pages
Open a command prompt and type the following command:
netsh winsock reset
This works wonders on mysterious networking problems like the one you describe here.
Hope this helps.
Feb 28, 2009 | Dell Inspiron E1505 Notebook
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Broadcom 440x 10/100 Integrated Controller driver will not load
Your resolution will most likely be a replacement of the motherboard. You can try flashing the BIOS and see if that resolves, but from your details it appears there is a hardware failure of the motherboard. Generally, you can find a motherboard for this model on Ebay for around $100
Jan 10, 2009 | Dell Inspiron 8600 Notebook
Broadcom 440x integrated controller drive will not load
...Others may DISAGREE with this repair, but I have done this on countless laptops with a SPILL...
This is a ..(LAST RESORT) fix...
remove the KEYBOARD, rinse THOROUGHLY under gaucet, while briskly wiping key surface with 2" paint brush... Shake dry. wrap keyboard in a BIG BEACH TOWEL, place it in SPIN DRYER, set for SPIN CYCLE (only), and.... let 'er go... Then AIR DRY it overnite, reinstall.
... If MoBo wasn't also damaged by spill, this may be your answer !! Doug R.
Jan 10, 2009 | Computers & Internet
Does dell dimension 2400 have ethernet card inside?? Basically when dell made the dimension 2400, did the put an ethernet card inside. Or do i have to buy one and install it myself? I have this Broadcom...
The 10/100 Integrated controller is the onboard network card
That basically mean yes it does have a network card built onto the motherboard.
If this helped please leave a Rating
Best of luck
Blazamane.
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
Wireless network adapter not recognized after reformatting
http://support.intel.com/support/wireless/wlan/sb/CS-010623.htm
go here and follow the steps to get the drivers and software to install.
dont know what o.s. you are running, but go into device manager, if you haven't already, to see if the apropriate drivers are installed and are enabled. let me know.
Dec 22, 2008 | Intel PRO/Wireless 3945ABG Network...
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Dell 430-0008 Network Adapter Logo
256 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
