Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Unwanted on screen dislay sharp tv lc-c3237u
Hi I have a shard lcd tv lc-c3237u 720. It has a a display in the top left hand corner that says 32" class 176 degree ultra wide pc input. I would like to know if there is any way that this can be removed from the screen. Please advise
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
  • 17 Answers
SOURCE: Can't find manual for Sharp
Have you tried this site?
tv.manualsonline.com/manuals/mfg/sharp/lcc3237u.html
Posted on May 21, 2011
  • 1348 Answers
SOURCE: the display on my tv wont go away, its in the top
some tv sets if the time and date is not set,the display will not go off
Posted on Jul 11, 2009
freelander72
  • 124 Answers
ps3 signal is 1080p you need a 1080p tv for it to be compatible.
Posted on Sep 17, 2009
Testimonial: "Thanks"
  • 8457 Answers
SOURCE: LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Posted on Jan 05, 2010
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
The upper left quadrant of my Sharp Aquos LC-65D64U does not display.
Check the connections of the flat cables that connects the T'Con board to LCD pane for any loose contact. Re-seat them. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window.
Dec 05, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
Hi Folks, I've got a sharp LC-26SA1E.The sound problem I have is that it only has 3 sound levels.None, Loud(30) and house shaking loud (60).There is an error code that has come up in the top left hand...
While tv is off press and hold buttons on tv VOL(-), A/V and switch it on, release buttons after 5sec.
Suppose to get back to normal state then.
I checked on my old sharp lcd lc-32ra1e and worked.
Oct 29, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Need a sharp 32 LC-32SB21U screen
Manufacturer Sharp Part Number LK315T3GW30R Description 32" VE PANEL ASSEMBL
Sep 04, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I get white dots upper left corner across the screen of set now I have a Sharp LC-37D40U LCD TV. Is it the pixels?
Hi Yabby,
If the dots are very narrow and jump about and you're receiving an analogue signal it could be teletext information. This is normal but is usually hidden off the top of the screen. You need to adjust the picture height to take them off the top.
Regards
Andy
Jun 26, 2008 | Sharp Televison & Video
Hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Dec 23, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
315 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
