Question about APC Computers & Internet
Beeps once then shuts the system down. sometimes it beeps more than once, when the computer is not on.
May your ups battrey not proper charging,totaly discharged or toatly dead. charging voltage is not coming from transformer or main PCB.u have to see all thing which i noted above.tray it .
Posted on Sep 08, 2009
How do you reset your PS3
you hold da power botton n leave it press youll here 1 beap the sec. after it will shut back down. once it shuts down let go of da power botton then 2 once again you press n hold it down youll here da 1st beep sec. after youll here 2 beeps dats when u release it n itll request you 2 plug in the usb n control aswell follow da instruction n it will direct you 2 a menu dat has options of restarting system, tile restoration, rebuild database, ect.
Dec 06, 2011 | Sony Playstation 3 (PS3) Console
My keyless remote isn't working at all on my 2007 pontiac grand prix???? i even changed the battery and still not working, but i noticed my service tire monitor system is on all the time and that's when my...
When you change the battery on your key fob, sometimes you will have to reprogram it to your car's security system for it to function. Make sure your trunk and hood are closed along with all of the other doors, then get into the driver's seat and shut the driver's side door. Put your key into the ignition and click it into ACC mode which is to click it back one click. Wait momentarily until you hear a beep. Quickly now click it forward once and then back to ACC mode where you will then hear another beep.Now open the driver's side door and then shut it to hear the last beep signifying that you are now in Programming Mode.
Press and hold down both the lock and unlock buttons for fifteen seconds and listen for the beep which will signal that the fob has been programmed. Continue this for all existing and new fobs, you will be able to program four remotes to your Grand Prix and will have to do them all at once due to the memory being forgotten every time you enter Programming Mode. Once you have programmed all of the remotes and heard a beep for each one programmed, remove the key from the ignition to exit Programming Mode. You are now free to test your fobs and ensure that they all work.
Apr 02, 2011 | 2007 Pontiac Grand Prix GXP Sedan
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
Computer Beeps When Windows is Loading
First, you should be sure that the cooling fans are working properly. Especially the one that is on or directed to the processor. You'll need to open the system up to check this. Turn on the system and make sure all the fans are spinning fast. Now, check for lots of dust or dirt on the fans and processor heat sink. Most likely, the inside of your tower needs to be cleaned. If there is too much dust and dirt in the fans and on the processor heat sink, it can't cool itself and the system shuts down to prevent damage to the processsor once it gets to a certain tempature. I have seen this often. You will need to use a can of air on the fans and processor heat sink. There will be a lot of dust and dirt that will come flying up....which is good Then use a vacuum and a soft bristle attachment to get out the remaining dust. Put the system back together and you should be good.
Your manual should show you how to take the cover off your PC to access the motherboard.
I hope this helps you.
Apr 08, 2010 | Dell Dimension 8200 PC Desktop
Video game shuts down no error report at all
Go to your System(in Control Panel) and check if you have Service pack 3. If you have SP2, download the SP3!!!!
Dec 06, 2009 | Video Game Consoles & Games
Hi, my ps3 shutting down when I turne on the power
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 27, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Dell Dimension 8400 - screen goes black or just freezes, no mouse or keyboard input works. Power down and then power back up works fine for about 10 mins then same problem.
Does the computer emit any beeps? If so, how many beeps?
One quick loud BEEP, at start up means that all is loading OK. If you get more than one BEEP sound, than you could have Memory ( RAM ) that is, or has failed. Sometimes, if one of the internal fans has failed or is failing, a computer will start up, and than shut itsself down again. Look for any error messages that may come across the screen. Get on another computer, and search for "computer beep codes". If you have the original manual that came with the computer, sometimes it will list beep codes in it. As it has been pointed out, it could be the hard drive also, check the beep codes, that is a good place to start.
Jun 18, 2009 | Dell Dimension 8400 PC Desktop
When I switch on Acer Aspire 5315 get message "Configuring updates 3 of 3 0% complete" for a few second then pc shuts down restarts and goes back to the same configuring updates message just...
try starting the computer in safe mode. As the computer boots keep pressing F8 until you hear a beep. The computer will or should start in safe mode, once it has everything will look big, don't worry about that for now, click on start>programs>accessories>system tools>system restore and choose a date for when you know the computer was working without any problems. Once the computer has restored it will shut down and reboot. When/if asked what mode you want to boot/start your computer choose start windows normally. I hope this helps.
Oct 22, 2008 | Computers & Internet
Laptop beeped once as it shut down
Ya its a computer they are built to fail =). 1 beep is usually a normal sign. when you start hearing more then 1 beep then I might worry.
If you found this helpful I hope you will rate accordingly. If you have anything else ever in the future you can use the ask me feature at
www.fixya.com/users/leethedeuce
Thanks,
Lee
Jun 21, 2008 | Toshiba Satellite A135 Notebook
A21m keeps shutting down
Have you checked the ventilation area of the processor if it is blocked by dirt? It causes heat to processor, when it reaches a certain hot temperature, it automatically turns off to avoid further damage. Have it opened and be cleaned by a computer tech
Jan 24, 2008 | IBM ThinkPad A21m 2628 Notebook
Computers & Internet Logo
195 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
