Question about Dynasty DGRSC 30 Gas Kitchen Range
LOOKS LIKE NO GAS TO OVEN. GLOW STICK LIGHTS IS YELLOW-BROILER LIGHTS...GLOW STICK SAME COLOR AS OVEN'S
    President:
  • 2,976 Answers
You need a new thermostat for the oven. It isn't picking up the heat from the ignitor. They're relatively cheap and easy to replace.
Posted on Sep 06, 2009
  • 93 Answers
For some Dynasty stove, there is a gas shut off valve at the gas regulator for the oven, make sure you check that first, it is located at the bottom right hand side below the black pan ( press top ) of the top burners. Afterward oven still won't ignite, check voltage at oven ignitor, it should be approx. 110v, if not then you may have a bad safety valve or oven thermostat. if you have 110v at the oven ignitor but still won't ignite, use a Amperage meter to check the oven ignitor ( clamp on to one of the ignitor wire ), it should draw above 3AMPs ( if not, then you have a bad ignitor. Have fun.
Posted on Mar 03, 2010
Viking oven broiler will not ignite
Your gas valve would be my first guess. Is this broiler (and bake ) lit with a glow coil or spark probe that goes (goes click, click, to light)??
If spark probe, you will have to replace either gas valve or spark board.
If glow bar lights the broil but does not glow, then replace glow coil.
Oct 18, 2013 | Dynasty DGRSC 48-6G Gas Kitchen Range
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
I used the self clean and now the oven won't heat. The broiler still works.
Hi, The most likely problem is the igniter was damaged during the clean cycle. Take the floor out of the oven and the flame spreader. set the oven for 350. If the igniter does not glow turn the power off and pull the igniter out and check it with an ohms meter. If as I suspect it reads open you should replace it. If the igniter glows it still may be bad. The igniter should glow bright yellow to the point where you can't look at it. If it glows and uneven yellow/orange it's bad and again you should replace it. If you have any other questions please feel free to comment. Mike
Jan 03, 2010 | GE JGRP17 Gas Single Oven
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Dynasty DGRSC 30 Gas Kitchen Range Logo
553 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Jaime Hernandez
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
