Question about Hayward Pool Products Hayward Max-Flo 1 1/2-HP In Ground Pool Pump
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I could open the container that holds the chlorine pucks ... once I had performed this task and closed up the container again, I turned the master breaker back on and everything started up again. I then checked individual breakers (there is a problem with a ventilation fan in the pool area not working) to see if one had been tripped off. the first breaker I turned off happened to be the one that powered the pool pump ... when I turned it back on the pump would only hum for about 15 - 20 secs and then I heard it click off. the pump was very hot. I let it cool down completely ... it has been off now for 24 hrs. but when I turn the breaker on again, the pump just hums/drones for about 15 - 20 secs and then stops making any noise. what is the problem? is there a reset button?
    President:
  • Hayward Pool... Master
  • 1,378 Answers
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Posted on Sep 07, 2009
Pool pump squealing
sometimes the gasket from the wet side of the pump fail and the pool water enters the bearing assembly of the pump. if there is a descent pump store, they can change the bearings within an hour. otherwise, a new pump is the solution
May 31, 2014 | Hayward 1.5hp Max Flo Inground Pool Pump #...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a Hayward super pump for inground pool and after 4years it went out. It is plugged in to a 110 out let for that is what the guy wired it to.
WELL IT WILL WORK OK ON THAT . 230 IS THE BEST 115 IS THE CHEAP WAY. PUMPS NEED SERVICE NOW AND AGAIN , TAKE THE 4 BOLTS THAT HOLD THE MOTOR TO THE TANK BODY ,UN-PLUG IT AND BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. BEARING & SHAFT SEAL AROUND $75. ..USE YOUR ZIP CODE IN YOUR SEARCH .. AND PRIME THAT PUMP AFTER ANY REPAIRS !!
HEY IF'N I WAS OF HELP ..VOTE .. JAY
May 26, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Pump wont run
does it turn freely if not check pump impeller for debris or damage repair or replace if necessary--if good- check motor bearings if not turning may need to be lubed or motor replaced check amp draw if spiked or nothing than possible open winding and may need replacement
Apr 08, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Pump was working fine yesterday popped the breaker
Hi Mohn,
Don't know your geographic location, but where I am we've been in the single digit temperatures for three days. Everything that can freeze has frozen.
If you are in a similar area, even though the water in the spa (I'm assuming the spa pump is being used on a spa) is heated, the pump housing isn't. If it iced up, it could very well cause the problems you describe.
Comment back with some more detail before I continue down what might be the wrong path.
Best regards
Mike
Dec 11, 2009 | Aqua Flo 2 HP Aqua-Flo Pump: 2" in/out,...
How do i remove the impeller from a self priming max-flow pump by hayward
Lock the shaft at the back of the motor and spin the impeller off counter-clockwise.
Oct 02, 2009 | Hayward Sp2805x7 Max-Flo 3/4 Hp Swimming...
Haywood 1.5hp power-flo matrix pool pump stopped working this morning --I checked and power is getting to timer ---all wires have good connections----pump is 2 years old----does the on/off switch at the...
There is a overload switch - somtimes inside the starter solenoid area.
While you have the pump disconected from mains power - check to see if pump impella turns freely.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pumps Capacity?
# Aboveground filter systems and small inground pools (under 10,000 gals) should use a Low Head pump like a Maxim, or Dynamo or Power-Flo. # Pools from 10,000-20,000 gals can use a Medium Head pump like a SuperPump, a Pinnacle or Cygnet. # Pools over 20,000 gals could possibly use the High Head pumps like, Super II, Challenger, Ultra-Flo or the Sta-Rite pumps. # Pool/ Spa combos with at least 3 lines influent and 2 - 3 back to the pool, 2" plumbing may be able to handle the Ultra High Head pumps like NorthStar and the WhisperFlo
Aug 27, 2008 | Hayward 2 Hp Max-Flo Swimming Pool Pump...
Hayward Pool Products Hayward Max-Flo 1 1/2-HP In Ground Pool Pump Logo
343 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
