Question about Rugged Notebooks General Dynamics Itronix GoBook VR-2 Notebook
Have 2003 itronz gobook, W/256k ram (upgraded from 128) can this be reupgraded to 512 or more? are there any CPU upgrades available affordably? can an ext hard drive or flash drive improve performance ( ihave a 120mg W/ @ 55mg still free internally)
  • 313 Answers
It depends on the model of the notebook. but I am going to say that it can because it is a 2003. but with out the model # I can't tell you how much you can put in.
Posted on Sep 08, 2009
Cannot find specification for packard bell i start 1379. I want to look into the possibility of upgrading this pc. Can anyone point me in the direction of the specs being available online for this...
Here is the homepage:
http://www.packardbell.co.uk/pb/en/GB/content/download
This specs provided was complete with a Intel Intel Serial ATA-300 ATA-133 PCI 160 GB Microsoft Windows Vista Home Basic , ATI Radeon Xpress 1100 128 MB 4 MB . The Desktops memory add up to 2048 MB , with standard memory 512 MB , memory installed 533 Mhz DDR2 SDRAM DIMM 240-pin Very low profile PC4300 Compact Flash Type I with 2 Expansion Sockets/Slots.
You can update the graphic, by adding a better graphic card, on the mainboard.
The ram can be upgraded to 2 gb ddr2 ram.
A bigger harddrive, can be added, for more space.
The cpu will be hard to find, it probably have socket 775, but this cpu is not available anymore.
And not all cpu`s will fit the mainboard.
Good luck
Feb 10, 2013 | Packard Bell (181368) Motherboard
Will Mercury 810e motherboard support 1.0 GB (512 MBX2) SD RAM?
I cannot directly answer that question because you did not supply the motherboard model number. You will have to look this up yourself, here is the url for Mercury support
http://www.mercury-pc.com/downloads.php
The model number is usually printed on the motherboard, find it and you can download the manual, specs and drivers.
Mar 06, 2017 | Q-Lity 810E-T (P3810E-T) Motherboard
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
SLOW need upgrades
If upgrading RAM is what you're thinking of - I'd suggest you don't. Only go to hardware consultants if absolutely necessary. Nowadays, if let's say you have 512 MB of RAM, it's still sufficient. If you need more because of high demand graphics software, then I would suggest you buy a machine with a greater RAM (pre-existing). There are other reasons a computer is slow. You could have malwares and spywares (run an antivirus scan). If it's clean and your machine is below 512 MB RAM, then I'd suggest to buy new machine.
Jan 26, 2010 | Itronix GoBook IX250 Notebook
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Want to upgrade ram pc2700 128mb to 512 mb , so i purchased a 512mb ddr1 400mz ram and put it in parallel port but my computer does not boot so i remove the 512 mb ram but problem was as it is now what...
first you check that your ram version.... i means it is compatible with your motherboard...if still prob remains then remove your all ram insert 128 mb ram then restart the system....... upgrade ram should fallow frequency of 512 mb RAM are same as 128 mb ram freqency........if mismatch is occured then it did nt wrked correctly...
Mar 30, 2009 | Computers & Internet
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
My hardware upgrade
all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
Mar 18, 2008 | Computers & Internet
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Rugged Notebooks General Dynamics Itronix GoBook VR-2 Notebook Logo
Top Rugged Notebooks Computers & Internet Experts
David Payne
David Payne
Are you a Rugged Notebooks Computer and Internet Expert? Answer questions, earn points and help others
