Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Print is light and there are lines. We just put
Print is light and there are lines. We just put in new cartridges for Black and Color and cleaned the printheads.
Put new black and color cartridges, will not print only black lines or when I use color, just color lines, I am only using copying not hooked up with computor , juststand alone copying
Maybe the printer need to clean a slot for a catridge. Because that printer stuck with old tint in the head for a printer therefore it need clean the heads.
Nov 27, 2010 | Lexmark X5150 All-In-One InkJet Printer
I put blue ink in a black cartridge and from then
Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
Compliments and wish you best of luck.
Jan 02, 2010 | Canon PIXMA iP1600 Printer
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
Oct 03, 2017 | HP G85xi All-Color InkJet Printer
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
May 20, 2009 | Canon i450 - Printer - color - ink-jet -...
HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Apr 14, 2009 | HP Deskjet 6940 InkJet Printer
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
My Hp 6210 is skipping lines and moving the paper down
note :--do not use refilled cartridges Step 1: Did you just install a new tri-color or photo cartridge? If all three of the following are true, the problem can probably be solved just by letting the printer sit for 30 minutes: You just installed a photo or tri-color print cartridge (the cartridge can be either new or previously-used) The problem appeared right after you installed the cartridge The recently-installed cartridge is the one that is printing the defective patterns on the diagnostic page Sometimes when a tri-color or photo print cartridge is snapped into the print carriage, it ingests a small amount of air, which can prevent some nozzles from working properly. The air soon works its way out of the cartridge. Step 2: Run the clean print cartridges utility If the step above did not solve the problem, clean the print cartridges. Press the Setup button. Use the arrow keys to select Tools and then press the OK button. Select Clean Print Cartridge and then press OK . The device prints a test page. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning. Open the Printer Toolbox . There are two ways to do this: Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox . If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints. Step 3: Clean the contacts If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage in the printer. Gather the following items to clean the cartridge and print carriage: Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap-water can contain contaminants that damage the cartridge. Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well) Sheets of paper or a paper towel to rest the cartridges on during cleaning Open the printer cover and wait until the print carriage stops moving. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles. Unplug the printer. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp. Clean the print-cartridge contacts. Do not touch the nozzles. Clean the contacts in the print carriage, inside the printer. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it. Reinstall the cartridge, plug the printer back in, and close the printer cover. Try to print again. If the issue still appears, proceed to the next step. Step 4: Black cartridges only: remove and rest for two hours NOTE: The following procedure does not fix missing lines or streaked bars printed by the tri-color, photo, or gray photo cartridges, or other color-printing problems. Perform the following steps only if the black print cartridge has printed defective patterns or if you notice non-uniform black text-darkness. In the black print cartridge, this problem might be caused by sediments collecting in the nozzle area. Perform the following steps to solve this problem: Remove the black print cartridge. If the carriage has a latch, re-latch it and then close the printer. NOTE: If the printer is not closed, it cannot adequately protect the remaining tri-color cartridge. Place the cartridge on a level surface with the nozzles up (label down). Allow the cartridge to sit undisturbed for two hours. Reinstall the cartridge and print another diagnostic page. Load letter or A4 unused plain white paper into the input tray. Press and hold the Cancel button and then press the Start Copy Color button. Make sure that the test patterns show a complete grid and the thick color lines are complete. More than a few broken lines in a pattern can indicate a problem with the nozzles. You might need to clean the print cartridges. If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black print cartridge in the right slot. If any of the color lines are missing, or if the pattern appears faded, streaked, or shows lines, this might indicate a problem with the tri-color print cartridge in the left slot. Look for defects on the page. If the diagnostic page shows no defects for the black cartridge, and if the cartridge was new, align the cartridge. To align the cartridge, follow the steps: Load letter, A4, or legal unused plain white paper into the input tray. In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Toolbox . NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device . The Printer Toolbox appears. Click the Device Services tab. Click Align the Print Cartridges and a print cartridge alignment sheet is printed. Load the print cartridge alignment sheet with the print side down on the right front corner of the glass. Press the Start Scan/Reprints button and the HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet. For aligning the cartridges from the hardware only, follow the steps: Load letter or A4 unused plain white paper into the input tray. Press and hold the Cancel button and then the On/Power button. While the Check Paper and Check Print Cartridge lights are blinking, press the following buttons one at a time in the following order: Cancel , Number of Copies , Paper Type , Color Start If the page still shows defects, go to the next step. Step 5: Replace the problem cartridge If the problem has not been solved by the steps above, either the printer or the problem cartridge is defective. If you have not tried cartridge replacement previously to solve this problem, replace the problem cartridge now. Click here to see if your cartridge is covered under warranty (c00059195). If you have already tried cartridge replacement and it did not help, service the printer. Preventing missing lines Missing lines occur when the cartridge nozzles dry out, or when a cartridge is running low on ink. Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it. After you have removed the protective tape, do not allow anything to touch the nozzles. Print at least once a month to keep the print cartridges in good working order. Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges. If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector. If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up.
Sep 07, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Printer wont print
On some of these inkjets, if the color cartridge is out or dried up from little use, they will not print using just the black cartridge.
Mar 30, 2007 | Epson Stylus Color 740 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
81 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
