Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
How do you replace the belt
I can not take it apart to replace the belt
  • 430 Answers
Check for a pair of screws at the outer edge of the brush housing area. On this unit I believe the unscrew form above. Then look for any others on the bottom plate below the the brush. Belts can break or burn thru. If your s has burned, clean the burned rubber from the motor shaft before replacing. Spin the brush roll, if it rolls smoothly remove it , place the belt over the motor shaft, then onto the brush and use the brush to pull into place.Check for hair and thread buildup at the end caps of the brush. The nylon caps pop off for cleaning.
Posted on Sep 07, 2009
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
I just need to get the power head apart to replace the belt. The two side tabs by themselves don't release the plastic...it is still firmly attached in the middle.
Look for a few screws under the machine, they will probably have Philips (star) heads. Remove these and the power head should come apart so you can access the belt and pulleys.
Feb 17, 2011 | Kenmore 23313 Whispertone Bagged Canister...
How do i replace the belts
I supposed you have a new belt. Take a screw driver take apart the screw and start taking apart the pieces where the belt is and just put it.
Dec 04, 2010 | Vacuums
Replace the belt on a Eureka contour model 2900 upright vaccum. I just want to see a picture of the way it comes apart. It a almost new and just needs the belt replaced.
I have listed below a link to the owners manual for your model and a link where you can purchase the belt you need. Hope it helps you!
Eureka Contour 2900 Owner's Guide
Eureka Contour 2900 Belt
Oct 26, 2009 | Vacuums
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
Broken belt
Hi.
If you cant easily see how to replace the Belt then I think your Dc07 has A clutch unit.
This type of Dc07 has 2 belts one from motor to clutch & the second belt goes clutch to brush roller.
You will need to remove the clutch unit completey from the machine in order to replace the belts, Its alot to explain so try this site it has service manuals covering this.
http://dysonmanuals.llc.nu/
Jul 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How do you take apart a hoover brush n wash to replace the belt
Generic problem for all Vacuums
How do you take apart?
How do you take apart a Hoover brush n wash to replace the belt?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
On a Hoover brushroll there are 2 types, wood and metal, and the metal can be washed with water and the wood should only be wiped off, knowing the name brand of the vacuum most of the vacuums the belt change is done by removing the bottom plate and exposing the belt, 1st hook the new belt around the brushroll and then use a screwdriver or similar with a bent hook on the end and then pull or hook the belt on to the motor pulley and then track the belt to make sure the belt stays on, then re-install the bottom plate and turn the vacuum on to test to see id the belt was installed correctly. The other is to look for 2 or 4 screws on the bottom and then remove the top cover and follow the instruction listed above without the bottom plate. A belt change should be done every 4 to 6 months on regular basics and to keep the belts in the refrigerator to keep them fresh.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874
Apr 21, 2008 | Vacuums
Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Sep 26, 2007 | Hoover Elite U5061-900 Bagged Upright...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
137 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
