Question about Cell Phones
K850 i wont start up
Keyboard lights up,thats it,nothing else. tried a new battery,still the same. tried removing and refitting the sim and memory card,no joy....
Help My laptop wont start up?
sounds like you Ram has blown (RANDOM ACCESS MEMORY) SIMPLE TO REPLACE'unplug from the mains turn the laptop over remove the battery you will see a few panels remove then to expose the RAM which is a chip about 3cm on and 1.5 wide two metal clips on the side pull them apart the chip will pop out ther may be two remove one and try to start the computer if it works then the one you removed is faulty on the chip it will be marked ( PC-333-5400) OR SOMETHING LIKE THAT this is the part you need to replace put the code in eBay order pop it in job done
Feb 11, 2012 | Computers & Internet
I have a Dell Inspiron E1705 laptop. The battery is testing as full; however, my laptop will not power on. I have removed the battery, let it set for 2 minutes, put the battery back in and have tried to...
Hi, Your computer power up but no monitor display as i understand. My advice is to remove the battery and remove the memory card cover, remove the memory card clean the memory card connectors with pencil eraser and wipe with cotton with alcohol and reinstall the memory card and the cover. Reinstall back the battery and press the on /off switch, It should power up and you will have display. I hope this will help you to solve your problem. Have a happy New Year... HRH
Dec 30, 2010 | Dell Inspiron E1705 Notebook
Z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
Always show the message 'insert sim card', When I refitted the SIM and turned back on, I had no network coverage. it always again n again n again..
Hi,when a phone does that, it means that the memmory of the phone is malfunction and it needs to be restored..
To be able to restore back the phone memory, you will need to flash the phone memory.
The links below will give you a guide line on how to flash the phone memory .
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 25, 2010 | Sony Ericsson K530i Cellular Phone
My Inspiron won't turn on, with the battery in the laptop, or with the battery and the adapter plugged in, or the adapter plugged in and battery out. Simly does not turn on at all. (Little red battery...
Make sure nothing is plugged into any USB ports as this can cause such issues. If the optical drive is removable, take that out too. If you can pull the memory out, do so. If the problem remains, you almost certainly have a bad system board.
Apr 28, 2010 | Computers & Internet
Computer wont start(Plz Help me ) Added Much Detail as possiable
start by removing everything, ram, any cards plugged in, drives etc. Then try and boot it. If the issue is still present, shut it down and remove the heatsink and cpu. I have known CPU's to be jolted out of their sockets after an impact. Take the heatsink off, lift the lever and remove the cpu. Check that all the pins are still aligned and straighten any bent pins then refit the cpu and lock the lever down. Refit the heatsink making sure that the heat transfer pad or heatsink paste is still present and lock it down. Plug the power cords and front panel wiring back in and try and boot it. If it boots, shut down and refit each item you removed one at a time, booting in between each item. If the issue arises again, the last item you fitted is the culprit. If you can refit everything and boot the system up, lady luck is with you. If you still cannot get it to boot after refitting the cpu, replace the mainboard. Sorry but without special gear, locating a fault like this on a mainboard is a real pain..
Dec 20, 2009 | Biostar G31-M7 TE Motherboard
Medion 2080 notebook battery wont charge
Time for a new battery. If you have a batteries plus in your area or order online.
Aug 13, 2008 | Medion MD-40954 Notebook
My IBM thinkpad a20m wont turn on
A couple of minor things that could cause this is the battery and memory. Try starting without the battery. Then remove the memory and try it with one chip in, then change them out and try. If these don't work, then the problem will lie with the motherboard, and will need professional diagnosing in order to locate the problem board component.
Jul 18, 2008 | Computers & Internet
Sony ericsson k850i won´t start up
hey, i had that issue to, on my k850i , i stoped it to change the sim , and when i started only the keyboard lights were on and the camera blue ring.. same thing like you. You can fix this by updateting the phone. Instal the update service select the k850 and fallow the instruction. after update the phone works fine.. sorry my bad english, hope you understand
Jun 18, 2008 | Cell Phones
Computer wont start
Nothing is booting ......when in earnest I say that is the BIOS screen at the beginning not going too. When you say the lights all go but the computer does not BOOT can you clarify please what goes. Now you say the processor fan does not work I imagine you are INSIDE the unit to know this try pushing down on the CPU firmly with your hands it may have dislodged slightly it can do this sometimes.....Ive seen it happen. Now for the not booting I need to know what is if any?.
Sep 05, 2007 | Compaq Armada E500 Notebook
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
